problem with range variable
problem with range variable - function of range variable gives type error - Сообщения
#1 Опубликовано: 06.12.2018 20:05:32
Steve22
Steve22
Hi, the attached sheet defines a simple function Qout(Qin) based on if statements. The function works for single valves of Qin. However, I'd like to plot Qout(Qin) so I defined Qin as a range variable. The function doesn't work and gives me a type conversion error. I'm a newbie to smath, please can you advise what I'm doing wrong? I've been through the documentation and examples and can't find anything. pump station2.sm (9,88 КиБ) скачан 1091 раз(а).
#2 Опубликовано: 06.12.2018 22:13:21
Hi, the attached sheet defines a simple function Qout(Qin) based on if statements.The function works for single valves of Qin.However, I'd like to plot Qout(Qin) so I defined Qin as a range variable.The function doesn't work and gives me a type conversion error.I'm a newbie to smath, please can you advise what I'm doing wrong?I've been through the documentation and examples and can't find anything.
That's as far I understand the problem. It needs more fabrication.
It should work in your latest Smath. If you have more interest,
I can probably find a model function to the pump curve.
As your are nwe in Smath Community: please, do not hesitate.
pump station2.sm (21,29 КиБ) скачан 1085 раз(а).
Steve22 06.12.2018 23:32:00
