Stable: SMath Studio 1.0.8253 (06 August 2022) - Сообщения
SMath Studio
Изменения, входящие в версию 1.0.8253
Улучшения
- Doubleclick on the unit placeholder (at right-hand side of the calculation result) opens Insert Unit dialog with suggested dimension now;
- Go to Definition command opens Insert Unit dialog with unit/dimension details when applicable now;
- Units dialog improved to display unit definition;
- Approximately not equal operator implemented.
Исправления
- Closing of the Worksheet when file saving is required fixed;
- Observations happens in some cases with Approximately Equal operator when comparing small numbers fixed;
- Command line functionality restored.
Разное
- Window with empty Worksheet is now automatically closed on open a file (no empty documents are generated now);
- Refactoring.
Скачать
SMathStudioAndroid.1_0_8253.arm64-v8a.apk (12,89 МиБ) скачан 5376 раз(а).
SMathStudioAndroid.1_0_8253.armeabi-v7a.apk (14,25 МиБ) скачан 4492 раз(а).
SMathStudioAndroid.1_0_8253.x86_64.apk (13,1 МиБ) скачан 4304 раз(а).
SMathStudioAndroid.1_0_8253.x86.apk (13,65 МиБ) скачан 4163 раз(а).
SMathStudioDesktop.1_0_8253.Mono.tar.gz (1,99 МиБ) скачан 17057 раз(а).
SMathStudioDesktop.1_0_8253.Setup.msi (3,14 МиБ) скачан 64528 раз(а).
SMathStudioDesktop.1_0_8253.x86_64.astra-orel.glibc2.24.AppImage (10,01 МиБ) скачан 6313 раз(а).
SMathStudioDesktop.1_0_8253.x86_64.ubuntu-22_04.glibc2.35.AppImage (12,46 МиБ) скачан 6886 раз(а).
- Desktop (Windows):
Framework: .NET Framework 2.0 or higher - Desktop (Linux):
- [ARA] Arabic / العربي
- [BEL] Belarusian / Беларуская
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CHS] Chinese (Simplified) / 简体中文
- [CHT] Chinese (Traditional) / 簡體中文
- [CPP] Portuguese (Brazil) / Brazil (Português)
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [IND] Indonesian / Bahasa Indonesia
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [POR] Portuguese / Português
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCC] Serbian (Latin) / Srpski
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SRP] Serbian (Cyrillic) / Српски
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
- [UKR] Ukrainian / Українська
SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Article.Eng.pdf (Date: 23.09.2009. File size: 828.96KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.IOFiles.Article.Eng.pdf (Date: 27.09.2009. File size: 453.24KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.NumericFunctions.Article.Eng.pdf (Date: 18.10.2009. File size: 622.45KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Programming.Article.Eng.pdf (Date: 18.10.2009. File size: 411.74KB) - to open in Adobe Acrobat Reader
SMath Studio icons (
SMathStudio.Icons.zip (Date: 12.04.2010. Size: 63.74KB)
So, doing a clean OS install and I checked to confirm the latest version. The portable version of 1.8151 did NOT let me know that there was an update available...
WroteThank you. I haven't been here much, but always support and appreciate the work that has gone into this project.
The "don't check for updates" checkbox is unchecked?
![2022-08-09 17_44_43-SMath Solver - [Worksheet1].png](/ru-RU/files/Download/XycLTX/2022-08-09-17_44_43-SMath-Solver---[Worksheet1].png)
WroteThe "don't check for updates" checkbox is unchecked?
Davide,
That is correct. This is for the portable version. Looks like Andrey posted 4 days ago and I was the first comment ... maybe others didn't get the update pop-up message on their full install as well.
Time to reload my OSesesesese.
Я хотел бы использовать в расчётах момент, но до сих пор не нашёл. Положи пожалуйста в SMath (изгибающий момент, вращающий момент, крутящий момент - единицы 'Nm' и 'kNm').
Я нашёл ещё ошибку в венгерском языке, 'Ellenálás' не правильно, надо писать 'Ellenállás' (по-русски сопротивление).
Kaderász Péter
Мне также неудобно что всегда нужно ручно изменить J на. 'N*'m. Но так и будет при наличии 'Nm т.к. это вряд ли хорошая единица по умольчанию для всяких величин размерности сила на длину. Скорее вчего для большинства имеется в виду работа или энергия.
Updating from 1.0.8151 to 1.0.8238 broke background printing of smath document. I used to be able to copy paste the file onto one note page (for collaboration), right click on it and "insert as printout" (see screenshot). This functionality broke down with switch to 1.0.8238. I will stay at 1.0.8151 for now.
Cheers
Sasha
