Regions disappear when using assignment :
Regions disappear when using assignment : - Сообщения
#1 Опубликовано: 01.06.2012 07:45:01
Here is an example of region disappearing v094.4535.
Region disapper by using :
and the video file as well
Regions disappear
It seems it happened under some circumstances when using assignment operator.
#2 Опубликовано: 01.06.2012 07:53:16
sequence to reproduce the issue: ~ -> f -> ( -> x -> "->" -> :
the ~ can be obtained by typing "Alt" + 0126 (from numpad)
I think the bolded function obtained by typing ~ before the name can be very interesting, would be nice the bug fixing will not disable it
bolded_function
regards,
w3b5urf3r
#3 Опубликовано: 01.06.2012 08:55:43
Hello w3b5urf3r_reloaded,
I think the bolded funtion obtained by typing ~ before the name can be very interesting, would be nice the bug fixing will not disable it
The workaround by the time of resolving this bug would be to use numerical equal to when you define an absolute function for the first time. The assignment operator would appear then.
Davide Carpi 01.06.2012 09:07:00
#4 Опубликовано: 01.06.2012 09:31:13
Hi omorr,
It's true, thank you!
I think can be useful for Andrey to find the bug
regards,
w3b5urf3r
#5 Опубликовано: 03.06.2012 17:57:18
2271 сообщений из 3734 понравились пользователям.
Thanks! Fixed.
Radovan Omorjan 03.06.2012 18:07:00, Davide Carpi 04.06.2012 03:33:00
