UPDATED: RC5: SMath Studio 0.98.6123 (06 October 2016)
UPDATED: RC5: SMath Studio 0.98.6123 (06 October 2016) - Сообщения
#1 Опубликовано: 05.10.2016 16:03:48
Release Candidate: SMath Studio 0.98.6122 available
Latest changes (against SMath Studio 0.98.6103)
  • [SS-2409]: Return value for indeterminate argument by UnitsOf() function fixed;
  • [SS-2318]: Preprocessing of symbolic data / functions' arguments finally fixed;
  • [SS-111], [SS-2327]: Fixed issues with functions arguments names interference;
  • [SV-2377]: Viewer: Issue when protected Area Regions was shown as tabs fixed;
  • [SS-2411]: Symbolic simplification of functions arguments fixed;
  • Detection of 0^0 error disabled for operations performed by numerical methods (like Integration or Gamma function);
  • Function range(3) improved to fix issues with lost last value of result vector;
  • Glitches happened sometimes on insert new Regions after collapsed Area Regions fixed;
  • About dialog extended to show if application is started in 32/64-bit mode;
  • Silent mode extended with -b argument (summary mode of output);
  • Consistency fix for el(...) function - when matrix used as indices (elements by row then by column);
  • Support for matrix as index feature added for sys(..) + several input errors handled;
  • Refactoring.
UPDATE: Changes against SMath Studio 0.98.6122
  • Support for units in range(2) implemented (base unit of the range start value used for increment);
  • Automatic scrolling to the Region just added to the Worksheet improved;
  • Incorrect location of Separator Region inserted by Ctrl+Enter press fixed (now it is added exactly on the place where cursor is located);
  • Visual glitches fixed when using Ctrl+Click functionality to select Regions on the Worksheet;
  • Special Region placeholder is now shown instead of incorrectly loaded Regions on file open;
  • Refactoring and code simplifications;
  • [Against to 0.98.6122 only]: Support for units in range(3) restored;
  • [Against to 0.98.6122 only]: Hotkeys for Math Regions restored.
Download
8 пользователям понравился этот пост
NDTM Amarasekera 05.10.2016 16:15:00, Radovan Omorjan 05.10.2016 17:55:00, Mike Kaganski 05.10.2016 18:23:00, bdrunagle 05.10.2016 18:50:00, Davide Carpi 05.10.2016 18:57:00, Вячеслав Мезенцев 05.10.2016 23:16:00, sergio 06.10.2016 04:48:00, Василий Николаевич Храмушин 06.10.2016 10:29:00
#2 Опубликовано: 05.10.2016 19:17:22
Mike Kaganski
Mike Kaganski
I seem to be unable to use "[" shortcut to el() function.
Edit: The same for root ("\" )
С уважением, Михаил Каганский
Radovan Omorjan 06.10.2016 06:39:00
#3 Опубликовано: 05.10.2016 19:54:07
Mike Kaganski
Mike Kaganski
Units are lost in range(2):
Radovan Omorjan 06.10.2016 06:42:00
#4 Опубликовано: 06.10.2016 06:40:17
Confirmed
#5 Опубликовано: 06.10.2016 06:42:00
Confirmed
#6 Опубликовано: 06.10.2016 10:18:03
Mike Kaganski
Mike Kaganski
Problems with "[", "]", "\" and units in range are fixed in appVersion(4)="0.98.6123.7493"
Igor Skarine 06.10.2016 10:29:00
#7 Опубликовано: 06.10.2016 11:09:45
Thank you Mike!
Yes, issues you have found are fixed (not only thoose ones) and new build created.
Please see updated first comment for list of changes.
Best regards, Andrey Ivashov.
Mike Kaganski 06.10.2016 18:02:00, Serg 06.10.2016 15:00:00
#8 Опубликовано: 07.10.2016 12:46:07
GreatGehar
GreatGehar
Hello.
In Windows version I insert image on the document page and save it. After I open this document on the Linux and don't see image. But on Windows image be show.
(Sorry for bad English)
#9 Опубликовано: 07.10.2016 13:15:43
Alexander O. Melnik
Alexander O. Melnik
Hello.
If it is related to the "Image Region" please post in the corresponding thread of the plugin - I will attempt to help you.
