SMath new file loading mode
SMath new file loading mode - New page or new SMath instance for a new application - Сообщения
#1 Опубликовано: 09.09.2024 17:26:53
ioan92
ioan92
180 сообщений из 120 понравились пользователям.
When I have already loaded an application in SMath and I want to load another application, the last one is always loaded as a new page and not as a new instance of SMath.
Sometimes (only), I want that the new application to be loaded in a new instance of SMath instead of a new page. How could I handle this option.
The reason for my demand is based on the intention of being able to run two or more applications on different screens of the same computer.
Thank you for your attention,
Ioan
#2 Опубликовано: 09.09.2024 19:09:13
StvMath
StvMath
44 сообщений из 71 понравились и 1 не понравились пользователям.
Just start another instance of SMath first, then load the other application in that.
ioan92 09.09.2024 19:28:00
#3 Опубликовано: 09.09.2024 21:45:47
ioan92
ioan92
Thanks,
It's perfect !
#4 Опубликовано: 10.09.2024 09:48:42
oscar mauricio
oscar mauricio
1 сообщений из 10 понравились пользователям.
I normally don't start two instances of the application because when closing one of the instances an error is generated in the images inserted with the ImageRegion plugin of the instance that remains open.
I hope you can fix this.
#5 Опубликовано: 10.09.2024 14:54:33
I've found where is the issue, I can fix it.
ioan92 10.09.2024 17:43:00
#6 Опубликовано: 10.09.2024 18:48:04
Fixed. Seems that the Release manager doesn't work currently, so the plugin can't be updated, but the code is uploaded in the SVN.
The temporary folder that contains the images generated on the fly by the plugin now has a sub-folder for each instance of the program, therefore the issue shouldn't arise anymore (BTW probably it was already reported before).
oscar mauricio 10.09.2024 19:32:00, ioan92 10.09.2024 20:37:00
#7 Опубликовано: 11.01.2025 02:43:26
Plugin updated
Andrey Ivashov 11.01.2025 04:26:00, sergio 11.01.2025 16:19:00, Alvaro 12.01.2025 15:48:00
