SMath crashes when opening a project
SMath crashes when opening a project - the problem with the text region - Сообщения
#1 Опубликовано: 27.11.2021 05:53:40
Artem
Artem
1)If you add an empty text region to a text region and save the project, SMath freezes and crashes when you try to open it again.
At the same time, if you add a non-empty text area to the text area, the project will open after saving
2)If you add a text region to the test region and try to select both regions and change the font size of the text regions, SMath freezes and crashes
#2 Опубликовано: 28.11.2021 07:15:40
587 сообщений из 1 360 понравились пользователям.
This is the error I corrected some users documents time to time.
It requires manually editing the smath file with a text editor.
