Signals and Systems - Example of use of SMath for signals and systems analysis - Сообщения
However I've edited the link, now it downloads the file, whatever is your favorite browser.
Thanks Davide!!
The post shows a trasfer function solved for the poles and zeros... It looks like you have to know how many poles and zeros to solve for before getting going. That would require putting the transfer function in standard form I'm somewhat sure.
https://electronics.stackexchange.com/questions/243435/bode-plot-of-transfer-function?rq=1
WroteI'm still trying to get the hand of this software. I'm an e.e. undergraduate and would like to be able to perform the something like the mathcad at the end of this post. I did try to input a similar syntax but I'm too much of a noob to work it. Can anyone shed some light on this for me?
All documents attached are in Smath 6179, should work same imore recent version(s).
The Smath/Maple companions of this year [2018] work a bit different than Mathcad 11 [2003].
At the end, all attached documents work for me Smath 6179 same as my former Mathcad 11.
Inst_PID [ODE].sm (24,75 КиБ) скачан 1031 раз(а).
Inst_PID Discrete State Systems.sm (25,51 КиБ) скачан 1253 раз(а).
Inst_PID DynSys.sm (14,9 КиБ) скачан 1173 раз(а).
Inst_PID [PI, PID].sm (71,51 КиБ) скачан 1039 раз(а).
Inst_PID [P, PD].sm (106,94 КиБ) скачан 982 раз(а).
Inst_PID Feedback Attenuator.sm (43,76 КиБ) скачан 1202 раз(а).
Inst_PID [MCD Model].sm (177,96 КиБ) скачан 1036 раз(а).
Inst_TurboGen Smath.sm (106,19 КиБ) скачан 1219 раз(а).
ODE_Laplace Read First.sm (27,41 КиБ) скачан 1234 раз(а).
Inst_TurboGen Signum.sm (91,08 КиБ) скачан 1248 раз(а).
Inst_PID Discrete Schema.sm (166,36 КиБ) скачан 1261 раз(а).
ODE_Laplace 1rst [Type 1].sm (24,7 КиБ) скачан 1040 раз(а).
Inst_XFR 2nd [XFR nth].sm (34,08 КиБ) скачан 1056 раз(а).
ODE_Laplace 1rst [Type 2].sm (22,5 КиБ) скачан 1101 раз(а).
Inst_PID DynSys_v01 (1).sm (235,59 КиБ) скачан 1225 раз(а).
ODE_Laplace 2nd [Type 3].sm (33,42 КиБ) скачан 1060 раз(а).
ODE Laplace Kinetic Reaction.sm (93,13 КиБ) скачан 1224 раз(а).
Here's an example of how one might attack it.
Page1.sm (44,98 КиБ) скачан 1424 раз(а).
Bravo! Alyles, simple and beautiful!!
WroteJean,
What why the invlaplace I get a dot?
Basile, mon ami, you need a new pair of glasses !
Just code as the snippet, it will gladly work for Basile.
Until I get my new pair, I see that a dot appears after the F(s) when I type a comma.
Any diagnosis?
Inverse Laplace-2.sm (4,25 КиБ) скачан 1195 раз(а).
Basile
WroteJean,
Any diagnosis?
Check from "Options" if you can fix .
Can you be more specific?
Basile
WroteJean,
Basile
From the menu tool bar up top work sheet:
Tools => Options => Interface => Arguments separator [period, coma, semicolon]
Thank you,
Basile
People have done some amazing things with it that I can't even begin to follow but I haven't been as successful. Perhaps as I become more competent I might be more successful but for now I think I will unfortunately have to hang up my hat gentlemen... I bid you a respectful adieu for the time being kind Sirs...
magnetism.zip (5,26 МиБ) скачан 460 раз(а).
WrotePerhaps as I become more competent I might be more successfu
I have doctored few things in these two documents.
hw 2.6.sm (133,49 КиБ) скачан 1203 раз(а).
open loop gain from closed loop gain 2.sm (48,32 КиБ) скачан 1199 раз(а).
WroteHi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expresed in F(s) form.
enjoy
Oscar Campo
Hi. Enjoyed & Improved. Six years later.
InvLaplace2.sm (93,88 КиБ) скачан 1229 раз(а).
WroteEnjoyed
Thanks Alvaro for your dedication,
Does syntax error 6179, but does not to where it complains.
Don't worry, OK like this.
The 2nd example is lot more involved, correct [sanity MCD].
InvLaplace2 Otherwise.sm (27,68 КиБ) скачан 1257 раз(а).
