Signals and Systems
Signals and Systems - Example of use of SMath for signals and systems analysis - Messages
#21 Posted: 8/28/2017 2:28:47 PM
Oscar Campo
Oscar Campo
135 likes in 309 posts.
However I've edited the link, now it downloads the file, whatever is your favorite browser.
Thanks Davide!!
#22 Posted: 8/28/2017 8:58:29 PM
Thanks Davide for the WS.
"assume" is often needed as well as "real".
The most common is "allvalues". It expands
the more general RootOf.
#23 Posted: 8/29/2017 7:30:28 AM
#24 Posted: 8/29/2017 8:13:02 AM
#25 Posted: 7/5/2018 6:00:06 AM
Adriaan Knox
Adriaan Knox
0 likes in 25 posts.
I'm still trying to get the hand of this software. I'm an e.e. undergraduate and would like to be able to perform the something like the mathcad at the end of this post. I did try to input a similar syntax but I'm too much of a noob to work it. Can anyone shed some light on this for me?
The post shows a trasfer function solved for the poles and zeros... It looks like you have to know how many poles and zeros to solve for before getting going. That would require putting the transfer function in standard form I'm somewhat sure.
https://electronics.stackexchange.com/questions/243435/bode-plot-of-transfer-function?rq=1
#26 Posted: 7/5/2018 8:37:52 AM
All documents attached are in Smath 6179, should work same imore recent version(s).
The Smath/Maple companions of this year [2018] work a bit different than Mathcad 11 [2003].
At the end, all attached documents work for me Smath 6179 same as my former Mathcad 11.
Inst_PID [ODE].sm (24.75 KiB) downloaded 1031 time(s).
Inst_PID Discrete State Systems.sm (25.51 KiB) downloaded 1253 time(s).
Inst_PID DynSys.sm (14.9 KiB) downloaded 1173 time(s).
Inst_PID [PI, PID].sm (71.51 KiB) downloaded 1039 time(s).
Inst_PID [P, PD].sm (106.94 KiB) downloaded 982 time(s).
Inst_PID Feedback Attenuator.sm (43.76 KiB) downloaded 1202 time(s).
Inst_PID [MCD Model].sm (177.96 KiB) downloaded 1036 time(s).
Inst_TurboGen Smath.sm (106.19 KiB) downloaded 1219 time(s).
ODE_Laplace Read First.sm (27.41 KiB) downloaded 1234 time(s).
Inst_TurboGen Signum.sm (91.08 KiB) downloaded 1248 time(s).
Inst_PID Discrete Schema.sm (166.36 KiB) downloaded 1261 time(s).
ODE_Laplace 1rst [Type 1].sm (24.7 KiB) downloaded 1040 time(s).
Inst_XFR 2nd [XFR nth].sm (34.08 KiB) downloaded 1056 time(s).
ODE_Laplace 1rst [Type 2].sm (22.5 KiB) downloaded 1101 time(s).
Inst_PID DynSys_v01 (1).sm (235.59 KiB) downloaded 1225 time(s).
ODE_Laplace 2nd [Type 3].sm (33.42 KiB) downloaded 1060 time(s).
ODE Laplace Kinetic Reaction.sm (93.13 KiB) downloaded 1224 time(s).
#27 Posted: 7/5/2018 11:11:33 AM
Arie
Arie
94 likes in 285 posts.
Here's an example of how one might attack it.
Page1.sm (44.98 KiB) downloaded 1424 time(s).
#28 Posted: 7/5/2018 12:58:56 PM
Oscar Campo
Oscar Campo
Bravo! Alyles, simple and beautiful!!
#29 Posted: 7/5/2018 1:04:44 PM
You may attack for an export solution.
#30 Posted: 7/6/2018 8:56:39 PM
Basile
Basile
8 likes in 172 posts.
Jean,
What why the invlaplace I get a dot?
Inverse Laplace-1.sm (4.08 KiB) downloaded 1262 time(s).
Basile
#31 Posted: 7/6/2018 9:30:07 PM
Jean,
Basile, mon ami, you need a new pair of glasses !
Just code as the snippet, it will gladly work for Basile.
#32 Posted: 7/7/2018 11:57:01 AM
Basile
Basile
Jean,
Until I get my new pair, I see that a dot appears after the F(s) when I type a comma.
Any diagnosis?
Inverse Laplace-2.sm (4.25 KiB) downloaded 1195 time(s).
Basile
#33 Posted: 7/7/2018 2:28:49 PM
Jean,
Any diagnosis?
Check from "Options" if you can fix .
#34 Posted: 7/12/2018 8:05:19 PM
Basile
Basile
Jean,
Can you be more specific?
Basile
#35 Posted: 7/12/2018 11:15:48 PM
Jean,
Basile
From the menu tool bar up top work sheet:
Tools => Options => Interface => Arguments separator [period, coma, semicolon]
#36 Posted: 7/13/2018 9:21:09 AM
Basile
Basile
My glasses arrived!
Thank you,
Basile
#37 Posted: 8/23/2018 8:53:31 PM
Adriaan Knox
Adriaan Knox
After doing my best to incorporate sMath into my University workload for the past 6 months. From my magnetism class to my analog circuits class here at the University of California at Santa Cruz but it has been my experience that for every line of code I write that I generate many more while trying which are unproductive. I think the efforts made on this program are exemplary and I've donated $10 but I think unfortunately I will not be able to continue with it due to the learning curve being so steep.
People have done some amazing things with it that I can't even begin to follow but I haven't been as successful. Perhaps as I become more competent I might be more successful but for now I think I will unfortunately have to hang up my hat gentlemen... I bid you a respectful adieu for the time being kind Sirs...
magnetism.zip (5.26 MiB) downloaded 460 time(s).
#38 Posted: 8/24/2018 12:30:05 AM
I have doctored few things in these two documents.
hw 2.6.sm (133.49 KiB) downloaded 1203 time(s).
open loop gain from closed loop gain 2.sm (48.32 KiB) downloaded 1199 time(s).
#39 Posted: 9/21/2018 6:23:31 AM
Hi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expresed in F(s) form.
enjoy
Oscar Campo
Hi. Enjoyed & Improved. Six years later.
InvLaplace2.sm (93.88 KiB) downloaded 1229 time(s).
#40 Posted: 9/21/2018 11:43:32 AM
Enjoyed
Thanks Alvaro for your dedication,
Does syntax error 6179, but does not to where it complains.
Don't worry, OK like this.
The 2nd example is lot more involved, correct [sanity MCD].
InvLaplace2 Otherwise.sm (27.68 KiB) downloaded 1257 time(s).
