Using Data Exchange with Linux
Using Data Exchange with Linux - Can't access ODS file data in Linux - Сообщения
#1 Опубликовано: 08.10.2017 14:17:40
dlyon
dlyon
Hello!
I have a dual boot machine running Ubuntu 16.04 and Windows 10, and my files are on a thumb drive. When working in Windows the plugin accesses the ods file without any problem:
When working in Ubuntu however, I get "Path is empty". When I rename the file by removing "s" from materials I get "The File /path/material.ods does not exist". So It appears to be finding the file, but not able to read it:
The ods file was originally saved in LibreOffice Calc. I downloaded GNUmeric and saved the ods file in "strict" and "extended" file formats to be sure the problem wasn't with LibreOffice. I have the same problem with all versions of the ods file. I have tried using the full path name on the thumb drive and from the home folder, same problem on both. When I installed SMath last week I installed mono from the Ubuntu repositories, so it should be the last stable release.
Any suggestions would be of great help!
Thanks
Dave
ms file:
MAST.sm (3,49 МиБ) скачан 1270 раз(а).
#2 Опубликовано: 08.10.2017 14:39:41
Hello Dave,
I'll look into it as soon as possible.
It might be an issue with the zip library, but I'm not sure.
#3 Опубликовано: 12.10.2017 08:12:12
Just found the issue; as I was thinking, it's a problem in the zip library (#17745). I'll provide a fix ASAP.
