Help equation Solution
Help equation Solution - solve equation - Сообщения
#1 Опубликовано: 18.04.2020 07:24:19
Elton
Elton
I can't solve the equation below, I tried two options but none worked. Someone could help?
Elton Freitas
#2 Опубликовано: 18.04.2020 07:42:44
I can't solve the equation below, I tried two options but none worked. Someone could help ?
Please: attach the document for the missing data.
#3 Опубликовано: 18.04.2020 11:20:12
Let's start by observing that:
1) the "solve" function is native to smath but does not accept units of measurement (if you want to use it you must temporarily get rid of the units of measurement)
2) the "FindRoot" function you have defined relies on "solve" (see above)
3) in the "nonlinear Solver" plugin you will find a "FindRoot" function that can do for you and that manages the units of measurement
4) there are other features and plugins that can help you. I suggest you also consult Martin Kraska's Interactive SMath Handbook with lots of information and practical examples (you can find it in the tool you use to install plugins)
#4 Опубликовано: 18.04.2020 13:23:01
Elton
Elton
Yes. It is attached or attached.Modelo_Planilha de Calculos_OM_rev02.sm (2,2 МиБ) скачан 1092 раз(а).
Thank you.
Best Regard.
Elton Freitas
#5 Опубликовано: 18.04.2020 14:11:13
haweHofmann
haweHofmann
3 сообщений из 32 понравились пользователям.
a quadratic equation, solved algebraically?
MPa^2=((σ.solda)/(a.cordao))^(2)+3*((P.total)/(2*h*a.cordao))^(2)
sys(a.cordao≡-sqrt(4*h^2*σ.solda^2+3*P.total^2)/{2*MPa*h},a.cordao≡sqrt(4*h^2*σ.solda^2+3*P.total^2)/{2*MPa*h},2,1)
