Sqrt of a Matrix
Sqrt of a Matrix - PKlijn - Сообщения
#1 Опубликовано: 17.02.2013 04:52:32
PKlijn
PKlijn
I get the following error: "Matrix must be square" when taking the SQRT of a single column Matrix.
Is there some way to do this calculation?
#2 Опубликовано: 17.02.2013 05:38:14
Fridel Selitsky
Fridel Selitsky
One of the ways
Ek.sm (4 КиБ) скачан 1379 раз(а).
#3 Опубликовано: 17.02.2013 06:40:09
You may consider using lists (AKA "systems" ). If the input values are obtained as matrix, then the function sys2mat from the CustomFunctions
Plugin may help.
#4 Опубликовано: 02.03.2013 11:23:37
PKlijn
PKlijn
Thank you, that works!
