new version errors
new version errors - Сообщения
#1 Опубликовано: 04.02.2014 05:58:22
kaaden
kaaden
Hello
Since I tried to install the new version I get the following error
I have reinstalled version 4909 but still appear LoaderExcepstions errors at startup and the snippets are not users / local / programs ... they are in the folder (x86) Installation Smath
thanks
#2 Опубликовано: 04.02.2014 07:23:20
kaaden
kaaden
I can't work with matrix function
#3 Опубликовано: 04.02.2014 07:33:59
Can't reproduce - Win7 x64/SMath 0.96.5146
Could you attach a file that doesn't work for you?
#4 Опубликовано: 04.02.2014 07:47:38
kaaden
kaaden
I can´t do that, the same error with matrix
I'm working with 4909 version, but it occurs since I tried install 5146
My windows is W7 professional /64
#5 Опубликовано: 04.02.2014 07:56:34
Ok...
I can suggest you only to create a simple file to post here or to send an e-mail to the developper with the file (sometimes the bug comes from other functions/plugins/settings).
As additional hint you can try to delete the "%APPDATA%\SMath\extensions\plugins" folder and the "Program Files(x86)\SMath\Plugins" folders before installing the 5146 version...
#6 Опубликовано: 04.02.2014 08:08:41
kaaden
kaaden
http://en.smath.info/forum/yaf_postst2112_-SOLVED--HRESULT--0x800700C1.aspx
the same error, ok
SOLVED, unnistall with GEEKS, now it works fine with 4909 version
thanks
#7 Опубликовано: 08.02.2014 03:54:16
This issue appeared because of unmanaged Win32 (x86) plug-in installed for 64-bit platform. All you need to do to fix this issue - to close SMath Studio and remove all plug-ins installed before.
This was found by uni (thank you!) and together we found a permanent solution.
This will not happen anymore with next version of SMath Studio (plan to release it before next week).
IVR 08.02.2014 04:21:00, Вячеслав Мезенцев 08.02.2014 05:09:00, Davide Carpi 08.02.2014 06:52:00, ioan92 08.02.2014 14:53:00
