Stable: SMath Studio 0.99.7610 (01 November 2020) - Сообщения
SMath Studio
Изменения, входящие в версию 0.99.7610
Улучшения
- Program start up speed significantly improved;
- The following units added: klx, μT, mT, klm, μWb, mWb;
- Toolbox icons vectorized;
- Cloud: SVG icons for toolboxes in supported now;
- Better support implemented for OS dark mode.
Исправления
- Support for high dpi systems restored;
- importData() function improved to support special chars in path;
- Ohm unit representation fixed for Russian localization;
- Android: Scaled images supported now;
- Android: Filling in a text is fixed for some onscreen keyboards;
- Working with images on Linux fixed (save/open, copy/paste);
- Color of the underlined text corrected;
- Text which contains link shown underlined again;
- Toolbox icons made visible on Mono;
- Export to PDF fixed on Linux;
- Cloud: All units/function selection fixed into insert dialog;
- Splash screen layout fixed on Linux.
Разное
- Worksheets rendering quality normalized between Mono and .Net frameworks;
- Refactoring.
Скачать
SMathStudioDesktop.0_99_7610.Mono.tar.gz (1,42 МиБ) скачан 38471 раз(а).
SMathStudioDesktop.0_99_7610.Setup.msi (2,29 МиБ) скачан 89849 раз(а).
- Desktop (Windows):
Framework: .NET Framework 2.0 or higher - Desktop (Linux):
- [ARA] Arabic / العربي
- [BEL] Belarusian / Беларуская
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CHS] Chinese (Simplified) / 简体中文
- [CHT] Chinese (Traditional) / 簡體中文
- [CPP] Portuguese (Brazil) / Brazil (Português)
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [IND] Indonesian / Bahasa Indonesia
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [POR] Portuguese / Português
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCC] Serbian (Latin) / Srpski
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SRP] Serbian (Cyrillic) / Српски
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
- [UKR] Ukrainian / Українська
SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Article.Eng.pdf (Date: 23.09.2009. File size: 828.96KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.IOFiles.Article.Eng.pdf (Date: 27.09.2009. File size: 453.24KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.NumericFunctions.Article.Eng.pdf (Date: 18.10.2009. File size: 622.45KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Programming.Article.Eng.pdf (Date: 18.10.2009. File size: 411.74KB) - to open in Adobe Acrobat Reader
SMath Studio icons (
SMathStudio.Icons.zip (Date: 12.04.2010. Size: 63.74KB)
- efi
- dislin
- matlab c++
- octave c++
- probe properties
Regarding efi: I'm looking at the issue right now.
WroteI see that the following plug-ins handles 0 (zero) functions now:
- efi
- dislin
- matlab c++
- octave c++
- probe properties
Prode Properties: You need to install Prode first. The plugin is just a wrapper.
Matlab C++ Math Library: For x32 only, but I have one idea how to make x64 support available.
Mathcad EFI: Also only for x32, but it is possible to make x64 support.
DISLIN: The library itself has recently been updated. I will try to update the plugin by changing the way the functions are loaded.
Octave C++ Math Library: Also only 32-bit Octave library exists.
Edit: Nevermind, I have posted a solution for this.
https://en.smath.com/forum/yaf_postsm67797_Maple-Tools.aspx#post67797
I'm struggling with installation, unfortunately there is some error that I can't solve. I checked .NET Framework, try to reboot but it appears everytime. I'm working on Win 10 x64 ver. 1809
Is there somebody who might have an idea how to resolve it?
Older versions of SMath also struggles with the same problem ;/
Thanks for help
