1 страниц (7 вхождений)
Fit Methods Essentials - Fit Methods Essentials - Сообщения
Global fitting session [0 .. 14]
1. al_nleqsolve point select equalities
valid for noisy data via user piecewise linear.
2. Levenberg-Marquardt: generally valid [fails Frechet]
3. Cholesky matrix solver ... solves all, faster
model function(s) parameters, linfit components,
remarkable linfitCheby, polyorder, direct discrete data.
............................ rational fraction.
EMERITUS => Conjugate gradient Minimize(init,iter)
Genfit_0 Read First.sm (32,45 КиБ) скачан 1273 раз(а).
Genfit_2 L-M AUTOMATED PieceWise-Global Reflexive Copy.sm (69,25 КиБ) скачан 1313 раз(а).
Genfit_4 linfit HyperRobust [Ge Crystal] Copy.sm (82,26 КиБ) скачан 1097 раз(а).
Genfit_7 GenfitMatrix Copy Master ToolBox Copy.sm (62,69 КиБ) скачан 1302 раз(а).
Genfit_9 Chemist.sm (34,68 КиБ) скачан 1230 раз(а).
Genfit_5 LinfitCheby Order [HadCRU] Copy.sm (120,98 КиБ) скачан 1097 раз(а).
Genfit_8 Poly 000 Order System.sm (20,15 КиБ) скачан 1250 раз(а).
Genfit_3 L-M AUTOMATED PieceWise Carlos Original Copy.sm (130,72 КиБ) скачан 1288 раз(а).
Genfit_6 Rational Auto-init ITER [LongRange type_J] Copy.sm (123,72 КиБ) скачан 1047 раз(а).
Genfit_11 Pharmacokinetics LMSA ... [Carlos 2020].sm (50,36 КиБ) скачан 1100 раз(а).
Genfit_10 Frechet.sm (96,8 КиБ) скачан 1264 раз(а).
Genfit_13 NON-Linear.sm (37,25 КиБ) скачан 1298 раз(а).
Genfit_1 L-M AUTOMATED Carlos 20200115 [Exampless] Copy.sm (265,69 КиБ) скачан 1061 раз(а).
Genfit_14 AUTOMATED al_nleqsolve.sm (83,36 КиБ) скачан 1295 раз(а).
Genfit_12 Pharmacokinetics LM ... [Carlos 2018].sm (55,45 КиБ) скачан 1069 раз(а).
NDTM Amarasekera 28.01.2020 04:28:00
1 ... please: recycle Genfit_14
replace by high pro refreshed/augmented.
2. Add Genfit_15 [Thiele Procedure]
Genfit_15 Thiele Procedure [Carlos-Jean].sm (76,66 КиБ) скачан 1098 раз(а).
Genfit_14 AUTOMATED al_nleqsolve.sm (85,48 КиБ) скачан 1309 раз(а).
... add this Meritas to your tool box.
Genfit_16 MERITAS al_nleqsolve.sm (29,95 КиБ) скачан 1274 раз(а).
Hola Jean
This is my best setting for "Genfit_10 Frenchet" in SS-6179
with LM using 6 data, since an out of memory error occurs using all data.
SS-7251 solves it without any problem with all the data.
Genfit_10 Frenchet LMSA ..SS6179.sm (56 КиБ) скачан 1247 раз(а).
Genfit_10 Frenchet LMSA ..SS7251.sm (45,17 КиБ) скачан 1255 раз(а).
Carlos
Carlos
Hola Jean
Genfit_16 MERITAS resolved with LMSA in SS-6179 and SS-7251.
Genfit_16 MERITAS LMSA_SS6179.sm (53,02 КиБ) скачан 1287 раз(а).
Genfit_16 MERITAS LMSA_SS7251.sm (52,9 КиБ) скачан 1307 раз(а).
Carlos
Carlos
WroteHola Jean
This is my best setting for "Genfit_10 Frechet" in SS-6179
Thanks Carlos, got 9 points superb fit !
Next will check MERITAS ...
Genfit_10 Frenchet LMSA ..SS6179.sm (55,67 КиБ) скачан 1268 раз(а).
WroteHola Jean
Thanks Grand Doctor Carlos ...
So, my native SS 6179 suffers numerical issue
that SS 7251 cures in your SS 6179 ... Ah !
LMSA in native SS 6179 takes much higher TOL [typical 0.0001/0.00001]
F.B. Hildebrand wrote "fitting is an art ..."
Can't be more right !
