1 страниц (9 вхождений)
Analog Clock - A simple animation - Сообщения
ioan92 09.07.2013 11:21:00, Вячеслав Мезенцев 11.07.2013 13:12:00, Andrey Ivashov 10.07.2013 08:27:00, Fridel Selitsky 09.07.2013 14:27:00
Beautiful animation: To reduce the computation time can be operators "for", which do not depend on time, move out of the function cloc (s).
Best Regards,Ber7.
AnalogClock1.sm (22,29 КиБ) скачан 1255 раз(а).
Best Regards,Ber7.
Thank you ber,
this make the script faster and easier to read
Best regards,
Davide
P.S. worksheet updated
Best regards,
Davide
Davide,if your program to change the settings a bit, we get
"real" analog clock (all the arrows are moving continuously).
Best Regards,
Ber7
AnalogClock2.sm (21,44 КиБ) скачан 1305 раз(а).
Best Regards,
Ber7
I see, wonderful
Cheers to all!
This is my 5 cents to this thread. I only took some pieces of code from here and there, a little bit of make up, and.. voilá: my version of analog clock that works on "real" time
Updated 19jul2019 (Special thanks to [USERLINK]Razonar[/USERLINK]):
Annoying "purple line" eliminated. Path for sound files fixed. More realistic movement of hands clock.
MyClock2.sm (38,86 КиБ) скачан 1203 раз(а).
click_low.wav (171,1 КиБ) скачан 322 раз(а).
alarm.wav (891,03 КиБ) скачан 323 раз(а).
Hola Oscar. Very nice effects.
You can improve it multiply Play() by 1000 or something else but big. This avoid the horizontal purple line in the clock.
Also you define the location of the files as "D:\sound.wav". Using 1000*Play("sound.wav" ) searches sound in the same directory of the SMath file.
Finally notice that your blue hours hand jumps between hours, but not follow the actual movement of an hours hand clock. You need to take 1/2-1/6*el(NOW,1)-el(NOW,2)/600 as the arguments for sin, cos functions for place it between exact hours considering the minutes too.
WroteHola Oscar. Very nice effects.
Thanks for your suggestions
I've updated the file and I uploaded the new one, you can check it here.
