Conditionally created control
Conditionally created control - Is it possible to set the creation of a slider to be conditioned to some result? - Сообщения
#1 Опубликовано: 08.05.2019 19:48:13
João Felipe Seráfico Melo
7 сообщений из 62 понравились пользователям.
Hi, everyone!
I'll clarify my question with an example.
Let's say I create a radio button list to set the geometry of a cross-section to be Rectangular or Circular.
If I choose Circular, I only have to inform (via slider) it's diameter.
If I choose Rectangular, I have to inform a width and a depth.
In the latter, is it possible to set the creation of the second slider dependent on my radio button input?
Thanks in advance!
#2 Опубликовано: 09.05.2019 00:01:00
Slider is not much convenient compared to MCD 11.
SS slider had no use for me, not profitable in real projects.
#3 Опубликовано: 09.05.2019 00:05:48
... as you can see: up/dn counter and slider don't save settings.
They freak themselves like dog chasing tail. IMHO: useless except for demo.
#4 Опубликовано: 09.05.2019 08:52:35
They have, both from canvas and from dialog. So yes, it is possible to elaboratesome degree of automation based on the inputs. If the roads are too different probably would be better to use collapsed areas with backed layouts however.
#5 Опубликовано: 09.05.2019 14:43:25
... add odd/even/shaped polygons.
