special functions addin
special functions addin - special functions - Сообщения
#1 Опубликовано: 20.03.2019 17:00:32
The Cross
The Cross
0 сообщений из 73 понравились пользователям.
What does the special functions addin do, and how do you add it to the sheets?
#2 Опубликовано: 20.03.2019 19:51:28
Special functions is too large a word: anything that does something
wrt maths is a special function [Floor, Ceil, round, abs ...]
You can have lot more functions from already developed for purpose.
Gamma(x) 15 D, Si, Ei, Li, Polylog, Polygamma, Dawson, Whittaker,
plenty poly orthogonal, plenty distributions ... Airy CoC
Essential Fourier, Bessel from the f(x) menu
Already quite a few distributions from f(x) menu.
Better than plugin is a collection in work sheet.
that you can call via the command "include".
What's your wish list ...
#3 Опубликовано: 20.03.2019 19:52:25
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Britt. Actually SpecialFunctions isn't an "external" plugin, it was, but not any more. From an old SMath update:
"New functions added to the SpecialFunctions built-in plugin: importData(..), str2num(), num2str(), concat(..), findstr(.), substr(.), substr(..), strrep(..), strlen(), IsString() and error();"
So, it have some useful function, but not the usual math "SpecialFunctions". You can found them at other numerical plugins, like:
https://en.smath.com/forum/yaf_postst1775_AlgLib-3-1x.aspx
https://en.smath.com/forum/yaf_postst1918_DotNumerics.aspx
https://en.smath.com/forum/yaf_postst1965_Cephes-Math-Library.aspx
but this list ins't complete.
#4 Опубликовано: 20.03.2019 20:05:07
go to insert > functions... and play with the plugins dropdown to see what functions are carried by each plugin, also by Special Functions
#5 Опубликовано: 20.03.2019 21:42:25
Dionysios J. Pantazis
16 сообщений из 179 понравились пользователям.
Kinda like this.....
