Clipboard Region
Clipboard Region - Сообщения
#21 Опубликовано: 08.12.2025 12:59:40
zhkz
zhkz
3 сообщений из 14 понравились пользователям.
PLEASE REPORT HERE ANY ISSUE
hi Davide
glad to find this extension ,but it seems dont work when export value
for export variable value , click Right-pointing triangle then it comes to an error , nothing copied to clipboard
for import value to variable , click left-pointing triangle then it works as expect
I'm not sure if the problem is on my end or with the plugin.
#22 Опубликовано: 09.12.2025 18:13:52
Hello, I'll check it, at first glance seems an error plugin-side.
#23 Опубликовано: 11.04.2026 06:49:46
Norrah_Casper
Norrah_Casper
This is honestly such a lifesaver for moving data between SMath and Excel. Even with the occasional formatting quirks with negative values or scientific notation, it’s much faster than manual entry. I've found that using a quick 'str2num' or 'strrep' usually clears up those string issues in a pinch.
#24 Опубликовано: 27.04.2026 11:27:38
hi Davide
Found the issue, fixed code uploaded in the SVN. Can't release the plugin because (I think) there is an issue server side on the relase manager.
Цитата
warning MSB4243: The NuGet-based SDK resolver failed to run because NuGet assemblies could not be located. Check your installation of MSBuild or set the environment variable "MSBUILD_NUGET_PATH" to the folder that contains the required NuGet assemblies
possible solution (for Andrey/the devs): https://stackoverflow.com/questions/79259398/the-nuget-based-sdk-resolver-failed-to-run-because-nuget-assemblies-could-not-be
Отредактировано 27.04.2026 11:36:11
sergio 27.04.2026 15:44:40
#25 Опубликовано: 28.04.2026 13:53:52
SMath Israel
SMath Israel
4 сообщений из 2 632 понравились пользователям.
Группа: Administrator
Dear David,
The finding was caused by new project format. Andrey performed necessary adjustments. You may finish your work now.
Gleb
Davide Carpi 28.04.2026 13:58:05
#26 Опубликовано: 28.04.2026 13:59:58
Thank you very much!
Plugin updated
Andrey Ivashov 28.04.2026 15:37:50
