Beta: SMath Studio 0.99.6988 (18 February 2019)
Beta: SMath Studio 0.99.6988 (18 February 2019) - Сообщения
#1 Опубликовано: 18.02.2019 15:04:51
SMath Studio
Изменения, входящие в версию 0.99.6988
Улучшения
  • Single instance of application is used for all files to open from shell now;
  • Paper selected in Page Setup dialog can be set as default now;
  • Insert Function and Insert Unit dialogs extended to display count of plug-ins and functions/units.
Исправления
  • Copy/paste works in Header/Footer now.
Разное
  • Page Setup dialog improved to make Use by default button enabled only if values displayed in the dialog differs from the ones stored as default settings;
  • Loading performance improved (in case of many third-party plug-ins installed);
  • Refactoring.
Скачать
SMathStudioDesktop.0_99_6988.Mono.tar.gz (1,36 МиБ) скачан 2106 раз(а).
SMathStudioDesktop.0_99_6988.Setup.msi (2,23 МиБ) скачан 4419 раз(а).
frapuano 18.02.2019 15:25:00, sergio 18.02.2019 16:32:00, Radovan Omorjan 18.02.2019 17:47:00, Davide Carpi 18.02.2019 20:37:00, Igor Skarine 19.02.2019 18:17:00, overlord 19.02.2019 20:28:00, NDTM Amarasekera 19.02.2019 23:11:00
#2 Опубликовано: 19.02.2019 18:22:47
Igor Skarine
Igor Skarine
14 сообщений из 97 понравились пользователям.
Great job!
For some worksheets, it works now 3-4 times faster than previous beta (on Win10-64).
#3 Опубликовано: 24.02.2019 08:26:52
Martin_B
Martin_B
22 сообщений из 84 понравились пользователям.
Strings containing only spaces are converted to empty strings when the file is opened and when inserted with copy/paste (include, Post #119):
Andrey Ivashov 24.02.2019 15:37:00
