Long Calculation Times
Long Calculation Times - The calculation does not end in some of my loops and can keep going for over an hour unless I end it - Сообщения
#1 Опубликовано: 10.07.2020 19:23:57
huynha23
huynha23
I've tried CTRL+A and changing the optimization from symbolic to numeric on this sheet already, it did not help with my calculation run time. I'm hoping somebody can lead me in the right direction!
I've highlighted the loop that I'm trying to calculate.
I also tried running the sheet without any units and it took under a second to calculate. Is it normal for SMath to perform this way?
In-Class 2.6_1D conduction_SS and TS.sm (65,67 КиБ) скачан 1044 раз(а).
#2 Опубликовано: 11.07.2020 01:08:34
Hi. Check Delta_t.TS please.
#3 Опубликовано: 11.07.2020 08:46:57
You can enrich the project from the very beginning.
Page24 Enrich Project.sm (23,59 КиБ) скачан 1158 раз(а).
#4 Опубликовано: 12.07.2020 09:42:45
The attached project was completed in collaboration.with the Originator.
Very closely related to yours. Superb model fit c/w its inverse/solve.
Inst_Thermal Insulation Copy.sm (127,36 КиБ) скачан 944 раз(а).
#5 Опубликовано: 12.07.2020 09:54:50
... the associated model fit.
Genfit Thermal Insulation.sm (49,24 КиБ) скачан 992 раз(а).
