Symbolic resolution from mathcad to SMath-Studio - symbolic resolution from mathcad to SMath-Studio - Сообщения
In mathcad there are: simplify, expand, substitute, etc.
When I solve an equation, I have to use "maple". Can this be done without using it?
Mathcad to SMath Studio.sm (103,48 КиБ) скачан 1278 раз(а).
I know the maple plugin has at least some of the functionality you're looking for. Also you'll want to check out the Maxima plugin as that's very useful for solving symbolic equations as well.
Mathcad to SMath Studio.sm (102,93 КиБ) скачан 1361 раз(а).
WroteHow can I do a symbolic resolution in SMath-Studio?
In Mathcad there are: simplify, expand, substitute, etc.
Most Mathcad command line work as well in Smath.
ODE Maple Example Copy.sm (118,52 КиБ) скачан 1253 раз(а).
WroteMost Mathcad command line work as well in Smath.
... augmented version.
ODE Maple Example Copy.sm (134,42 КиБ) скачан 1305 раз(а).
Unfortunately SMath don't have this features natively.
WroteHi Valentino. This is a way.
Alvaro thank you very much, your solution has worked very well for me. I have a question, you use commands like "Collect" and "Opt" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement?
WroteWroteHow can I do a symbolic resolution in SMath-Studio?
Jean thank you very much for sharing your examples, they are great. I have a question, you use commands like "Conver" "Collect" "dsolve" and "invlaplace" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement? what are they for?
Which of these 6 styles do you prefer ?
Mathematica has a long discours on that .
How did you put so many "boolean equals" without the parentheses being uncertain?
¿Cómo pusiste tantos "iguales booleanos" sin que los paréntesis sean inciertos?
Thank you
WroteHow did you put so many "boolean equals" without the parentheses
From an old Mathcad/Mathsoft contest.
WroteJean thank you very much for sharing your examples, they are great. I have a question, you use commands like "Convert" "Collect" "dsolve" and "invlaplace" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement? what are they for ?
They just make the demand produce/solve.
Few more attached as you may need eventually.
Cheers Valentino ... Jean
Symbolic Convert Parfrac Primary FNCTS.sm (118,96 КиБ) скачан 1262 раз(а).
Wrote...I have a question, you use commands like "Collect" and "Opt" but they don't appear in "all my functions"; ...
Opt = Symbolic or Opt = None means that you must to right click over an expression, and choose Optimization / Symbolic or None, not a command.
About collect and other expression they aren't from SMath, but from Maple plugin, which is Maple version 6. So, you must to learn something about it. Maplesoft online help could be very extended: Maple help but you can also read some good manuals like "Aprenda Maple 8 como si estuviera en primero" from Universidad de Navarra (you can google it, it's free). Just a notice: Maple V have several differences about how handle strings and some other things, so if you can't find a good short manual about Maple 6 try only up versions.
Wrote¿Cómo pusiste tantos "iguales booleanos" sin que los paréntesis sean inciertos?
With some hard work you can hack the SMath syntax: From https://en.smath.com/forum/yaf_postsm56111_Some-future-requests.aspx#post56111
HackingEqual.sm (3,3 КиБ) скачан 1789 раз(а).
WroteFew more attached as you may need eventually
The continued fractions are not futile ... Explain.
Before the modern CAS, the main frame IBM, used continued fractions.
As well as the J_Fraction... Where is my Mathcad on that ?
Since then, the Padé normalized fractions have replaced
the continued fractions, more stable numerically, faster parallel.
Smath is not envious of PTC_Mathcad ... Jean.
Inst_TurboGen Smath [SHORT].sm (19,63 КиБ) скачан 1028 раз(а).
Inst_TurboGen Signum.sm (86,11 КиБ) скачан 1205 раз(а).
Inst_TurboGen Smath.sm (118,82 КиБ) скачан 1215 раз(а).
WroteWith some hard work you can hack the SMath syntax.
This is nice. I didn't know it could be done.
Formulas work even after brackets removed.
Not just a cosmetic removal.
Thanks a lot.
