Multi line text
Multi line text - Сообщения
#1 Опубликовано: 11.11.2010 18:34:26
László Radnay
László Radnay
0 сообщений из 9 понравились пользователям.
Hi!
Is it possible to use multiline text in smath?
I have just found singel line text.
Thank you for your help!
#2 Опубликовано: 11.11.2010 19:58:54
maweilian
maweilian
Yes, it is possible.
Create a text region as you normally would (i.e. using 'double quote' key). When you reach the end of a line, use Ctrl+Enter ( or Shift+Enter) to go to the next line. At this point, Smath has no automatic text wrapping.
See this wiki page for more keyboard shortcuts: Keyboard Shortcuts
#3 Опубликовано: 12.11.2010 04:08:24
Yes, unfortunately there is no word wrapping. We should be careful when typing text lines in order not to pass over the right edge of the printing area. Print preview can help here.
#4 Опубликовано: 19.11.2010 06:25:38
László Radnay
László Radnay
Hello!
Thank you for your help! It works, and it helps me a lot!
#5 Опубликовано: 05.11.2014 14:05:36
zapzapouch
zapzapouch
0 сообщений из 27 понравились пользователям.
Is this still true 4 years later? There are no plugins that provide a plain text box with word wrapping and non-monospace font, formatting of a few words and not others, etc?
#6 Опубликовано: 05.11.2014 14:15:01
Is currently under development (see here).
About the wrapping is a feature planned but I can't guarantee that this will be available soon.
