Maxima draw2d-Plugin
Maxima draw2d-Plugin - no view - Сообщения
#1 Опубликовано: 20.10.2018 11:41:50
Georg Gläser
Georg Gläser
0 сообщений из 9 понравились пользователям.
I have installed the MAXIMA - Plugin. It will be work
right, wenn I have work with Algebra, Infinity..
But when I get a Maxima -Draw then I get the
Grafibox with text: Maxima Draw Error "part: argument must be
a non atomic expression; found f"
Before I define f(x):=sin(x) . I give f, or f(x) in the draw-box
it doesendt work.
Plaese send help me.
Many thanks from Oktaeder
#2 Опубликовано: 22.10.2018 05:20:55
You use the same commands as you would use in Maxima. To plot a function f(x) use the command
explicit(f(x);x;min;max)
See the german handbook for examples.
If you think you found a bug, please attach your file.
