1 Pages (7 items)
Question about CheckBox - Messages
#1 Posted: 7/16/2022 4:08:36 PM
Hello. Important coefficient k=1.25. Sometimes you need to use it, sometimes you don't need to use it.I decided to take CheckBox. Here's what happenedFile not found.
I tried another way. I changed the formula using inactive check (K=0).Result is good with inactive checkFile not found.
But the result bad with active checkFile not found.
Question 1: Why did it happen?
Question 2: When inactive check, k=0.How can do k=1 with inactive check?
#2 Posted: 7/16/2022 4:42:03 PM
WroteQuestion 1: Why did it happen?
Answer 1: It is a long lasted bug/limitation.
SMath Viewer doesn't respect your decimal places in Smath Studio.
I had reported it 6 years ago, maybe it can't be fixable as it is.
https://en.smath.com/forum/yaf_postsm35182_SMath-Studio-0-98-6077--21-August-2016.aspx#post35182
However, you can round your results as you wish.
Answer 2: What I understood from your desire is;
If checkbox is active, then result should be matrix value.
If checkbox is inactive, then result should be 1.
You can do that with an if/else statement.
questions.sm (4.41 KiB) downloaded 1064 time(s).
Davide Carpi 7/17/2022 7:10:00 AM
#3 Posted: 7/16/2022 7:01:44 PM
WroteWroteQuestion 1: Why did it happen?
Great! Thank you very much!!
#4 Posted: 7/18/2022 1:54:10 PM
When adding units, the result has changed. When checkbox is inactive, everything is fine. When checkbox is active, units disappear.
#5 Posted: 7/19/2022 9:41:51 AM
1. your example
2. Davide Carpi tutorial 8 years ago.
Cheers ... Jean.
Maths checkbox.sm (22.86 KiB) downloaded 1083 time(s).
Maths checkbox DAVIDE.sm (18.66 KiB) downloaded 1104 time(s).
Cheers ... Jean.
#6 Posted: 7/19/2022 10:46:20 AM
#7 Posted: 7/19/2022 4:05:36 PM
1 Pages (7 items)
