Question about CheckBox
Question about CheckBox - Сообщения
#1 Опубликовано: 16.07.2022 16:08:36
Prmtv
Prmtv
0 сообщений из 49 понравились пользователям.
Hello. Important coefficient k=1.25. Sometimes you need to use it, sometimes you don't need to use it.I decided to take CheckBox. Here's what happenedФайл не найден.
I tried another way. I changed the formula using inactive check (K=0).Result is good with inactive checkФайл не найден.
But the result bad with active checkФайл не найден.
Question 1: Why did it happen?
Question 2: When inactive check, k=0.How can do k=1 with inactive check?
#2 Опубликовано: 16.07.2022 16:42:03
Answer 1: It is a long lasted bug/limitation.
SMath Viewer doesn't respect your decimal places in Smath Studio.
I had reported it 6 years ago, maybe it can't be fixable as it is.
https://en.smath.com/forum/yaf_postsm35182_SMath-Studio-0-98-6077--21-August-2016.aspx#post35182
However, you can round your results as you wish.
Answer 2: What I understood from your desire is;
If checkbox is active, then result should be matrix value.
If checkbox is inactive, then result should be 1.
You can do that with an if/else statement.
questions.sm (4,41 КиБ) скачан 1169 раз(а).
Davide Carpi 17.07.2022 07:10:00
#3 Опубликовано: 16.07.2022 19:01:44
Prmtv
Prmtv
Great! Thank you very much!!
#4 Опубликовано: 18.07.2022 13:54:10
Prmtv
Prmtv
When adding units, the result has changed. When checkbox is inactive, everything is fine. When checkbox is active, units disappear.
#5 Опубликовано: 19.07.2022 09:41:51
1. your example
2. Davide Carpi tutorial 8 years ago.
Cheers ... Jean.
Maths checkbox.sm (22,86 КиБ) скачан 1183 раз(а).
Maths checkbox DAVIDE.sm (18,66 КиБ) скачан 1199 раз(а).
#6 Опубликовано: 19.07.2022 10:46:20
... added User project administrator wrt 'k'
Maths checkbox.sm (15,03 КиБ) скачан 1173 раз(а).
#7 Опубликовано: 19.07.2022 16:05:36
If you have noticed, when checkbox is selected k is in vector and look like k=[1.25]
Alter the if/else statement as below.
