1 Pages (9 items)
how to plot discrete function - Messages
#1 Posted: 11/8/2022 2:37:51 PM
hi,
I am trying to create a sheet to design welds and want to plot the geometry of the weld lines.
the problem is if I assign a matrix with x,y coordinates the 2D plot will draw a continuous function connecting all points, and when I assign this to a discrete matrix of line coordinates it does not plot unless I assign each line individually which is bad as I want it plotted based on the geometry.
in the example below, I want the 2D plot to plot LW without manually adding each component of LW individually.
Thanks
Thanks
#2 Posted: 11/8/2022 3:18:08 PM
sergio 11/8/2022 3:53:00 PM
#4 Posted: 11/8/2022 4:20:38 PM
#5 Posted: 11/8/2022 4:51:40 PM
WroteI want the 2D plot to plot LW without manually adding each component of LW individually.
... it may be possible to make svg [Scale Vector Graphic].
Cheers ... Jean.
test_alyles & jean.sm (41.37 KiB) downloaded 1200 time(s).
#6 Posted: 11/8/2022 8:36:11 PM
#7 Posted: 11/8/2022 10:08:39 PM
... here is the project as offered.
Utilities Discrete COMPANION_2 WELD.sm (20.2 KiB) downloaded 1241 time(s).
#8 Posted: 11/9/2022 5:42:29 AM
4 users liked this post
sergio 11/9/2022 7:36:00 AM, NDTM Amarasekera 11/9/2022 9:42:00 AM, Arie 11/9/2022 9:42:00 AM, Alvaro 11/9/2022 6:32:00 PM
#9 Posted: 11/9/2022 6:34:13 PM
WroteYou might consider building geometry plots from the pre-defined objects in the XY-Plot-plugin. ...
And maybe you may be interested in this other Martin' post, if you want to draw steel profiles to be welded, and by the way calculate their mechanical parameters: https://en.smath.com/forum/yaf_postsm78221_Split-Areas-Polygons-convex-and-concave--by-lines.aspx#post78221
1 Pages (9 items)
