automatic show results of trigonometrie not in radians, but in degrees?
automatic show results of trigonometrie not in radians, but in degrees? - Messages
#1 Posted: 5/23/2019 5:15:36 AM
Paulius
Paulius
0 likes in 11 posts.
Hello the question is. Is it possible to make, that every time function antan returns in degree?
example:
atan(0.2/0.75)=0.343 every time I must add units "deg" that it returns not in radians. Maybe is possible to safe time and make change somethere in software. Thank You for the help
#2 Posted: 5/23/2019 5:35:37 AM
1,555 likes in 1,867 posts.
You can override atan() function.
Davide Carpi 5/23/2019 1:50:00 PM
#3 Posted: 5/23/2019 9:41:30 AM
Personalize like this as an utility at top of work sheet
to avoid conflict with the atan(x) built-in from Windows library.
Atan(x):=atan(x)*360/2*π
Atan(4)=75.964 then by personalized 75.964°.
Trig.sm (12.18 KiB) downloaded 1064 time(s).
#4 Posted: 5/23/2019 1:54:20 PM
It is already backed in the snippets section since a long long time.
evaluation in degrees
Вячеслав Мезенцев 5/23/2019 3:53:00 PM, frapuano 5/23/2019 6:43:00 PM
