automatic show results of trigonometrie not in radians, but in degrees?
automatic show results of trigonometrie not in radians, but in degrees? - Сообщения
#1 Опубликовано: 23.05.2019 05:15:36
Paulius
Paulius
0 сообщений из 11 понравились пользователям.
Hello the question is. Is it possible to make, that every time function antan returns in degree?
example:
atan(0.2/0.75)=0.343 every time I must add units "deg" that it returns not in radians. Maybe is possible to safe time and make change somethere in software. Thank You for the help
#2 Опубликовано: 23.05.2019 05:35:37
You can override atan() function.
Davide Carpi 23.05.2019 13:50:00
#3 Опубликовано: 23.05.2019 09:41:30
Personalize like this as an utility at top of work sheet
to avoid conflict with the atan(x) built-in from Windows library.
Atan(x):=atan(x)*360/2*π
Atan(4)=75.964 then by personalized 75.964°.
Trig.sm (12,18 КиБ) скачан 1064 раз(а).
#4 Опубликовано: 23.05.2019 13:54:20
It is already backed in the snippets section since a long long time.
evaluation in degrees
Вячеслав Мезенцев 23.05.2019 15:53:00, frapuano 23.05.2019 18:43:00
