format results polar in degrees
format results polar in degrees - How to show matrix results in polar format in degrees - Messages
#1 Posted: 10/12/2025 6:46:36 PM
Russ Patterson
Russ Patterson
0 likes in 5 posts.
I am one tiny step away from freeing myself of Mathcad Prime. I just need to know how to format the result of a matrix/vector operation so it is in polar form with angle in degrees. The attached image is a snip from a Mathcad result. How is this possible in SMath?
best regards,
russ
#2 Posted: 10/13/2025 6:58:46 AM
fominantokha
fominantokha
0 likes in 3 posts.
See
https://smath.com/en-US/forum/topic/kAz5NZ/How-to-do-polar-form-like-mathcad_
Edited 10/13/2025 6:59:51 AM
#3 Posted: 10/13/2025 1:40:26 PM
Russ Patterson
Russ Patterson
0 likes in 5 posts.
Thank you. That does not address formatting a vector result in polar with degrees (what I'm after) as best I can tell. I want to display my resulting vector in polar with degrees.
Also, I tested the "pol" function and it assumes the angle is in radians.
Worksheet1.sm (10.64 KiB) downloaded 523 time(s).
#4 Posted: 10/14/2025 9:09:21 AM
1,080 likes in 1,752 posts.
Hi. You can try something like this, using the table plugin.
showPolarForm.sm (18.3 KiB) downloaded 561 time(s).
Russ Patterson 10/14/2025 6:01:09 PM
#5 Posted: 10/14/2025 6:04:28 PM
Russ Patterson
Russ Patterson
0 likes in 5 posts.
Thank you. That works rather well.
1) Is there a way to hide that showPF function at top of my worksheet?
2) I can't figure out how to make it report a very tiny imaginary component as zero. See bottom of attached. showPolarForm.sm (20.74 KiB) downloaded 573 time(s).
best regards,
russ
p.s. It would also be great if we could control the table borders at an individual column level - so I can make it look like brackets around the results.
#6 Posted: 10/14/2025 6:27:56 PM
120 likes in 337 posts.
1) Menu --> Insert --> Area. Place the functions you want to hide between the two lines. Then click the little square with the – sign to collapse the area."
Russ Patterson 10/14/2025 8:42:47 PM
#7 Posted: 10/14/2025 10:59:16 PM
Hi. Modified version.
showPolarForm.sm (21.93 KiB) downloaded 578 time(s).
sergio 10/15/2025 5:42:32 PM, Russ Patterson 10/15/2025 8:51:43 PM
#8 Posted: 10/15/2025 8:51:58 PM
Russ Patterson
Russ Patterson
0 likes in 5 posts.
Outstanding! thank you
