1 страниц (8 вхождений)
format results polar in degrees - How to show matrix results in polar format in degrees - Сообщения
Thank you. That does not address formatting a vector result in polar with degrees (what I'm after) as best I can tell. I want to display my resulting vector in polar with degrees.
Also, I tested the "pol" function and it assumes the angle is in radians.
Worksheet1.sm (10,64 КиБ) скачан 1016 раз(а).
Hi. You can try something like this, using the table plugin.
showPolarForm.sm (18,3 КиБ) скачан 1054 раз(а).
Russ Patterson 14.10.2025 18:01:09
Thank you. That works rather well.
1) Is there a way to hide that showPF function at top of my worksheet?
2) I can't figure out how to make it report a very tiny imaginary component as zero. See bottom of attached. showPolarForm.sm (20,74 КиБ) скачан 1086 раз(а).
best regards,
russ
p.s. It would also be great if we could control the table borders at an individual column level - so I can make it look like brackets around the results.
best regards,
russ
1) Menu --> Insert --> Area. Place the functions you want to hide between the two lines. Then click the little square with the – sign to collapse the area."
Russ Patterson 14.10.2025 20:42:47
Outstanding! thank you
