The procedure for constructing a circle by three points in 3D
The procedure for constructing a circle by three points in 3D - Messages
#1 Posted: 12/31/2016 4:11:54 AM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Idea of ​​the algorithm taken from the publication of Alexey Ivanov
http://www.mapleprimes.com/posts/207697-Circle-In-3d-
The calculation algorithm
1. The three points are vertices of the triangle. Write three linear equations:
two equations of planes passing through the midpoints of the two sides of the triangle
perpendicular to these sides: f1 = 0, f3 = 0
and the equation of the plane which contains the triangle: f2 = 0.
2. Solve the system of equations and find the center of a circle with coordinates Cen xCen, ... zCen.
3. Find the circle radius R of the equation of a sphere with radius R and center at Cen
4. Construct a circle as the line of intersection of the sphere with the plane of the triangle (Draghilev method)
Okruzhnost'3.sm (55.35 KiB) downloaded 1292 time(s).
Davide Carpi 1/2/2017 12:40:00 PM, Oscar Campo 11/25/2017 12:44:00 AM
#2 Posted: 1/24/2017 1:22:48 PM
Fridel Selitsky
Fridel Selitsky
Modified the program
OkruzhnostMod.pdf (243.54 KiB) downloaded 893 time(s).
OkruzhnostMod.sm (67.93 KiB) downloaded 1252 time(s).
3 users liked this post
Davide Carpi 1/25/2017 6:32:00 AM, Oscar Campo 11/25/2017 12:44:00 AM, Arie 1/24/2017 7:58:00 PM
#3 Posted: 11/24/2017 6:43:33 AM
Fridel Selitsky
Fridel Selitsky
Changes:
1. Circle is constructed by matrix transformation, and not Draghilev Method
2. The normal to the surface passing through the given points is shown.
OkruzhnostMod3.sm (54.16 KiB) downloaded 1241 time(s).
Davide Carpi 11/24/2017 2:53:00 PM, Oscar Campo 11/25/2017 12:44:00 AM, frapuano 11/24/2017 8:35:00 AM
#4 Posted: 11/25/2017 10:33:16 AM
Thanks Ber7, saved.
#5 Posted: 11/25/2017 12:21:20 PM
Fridel Selitsky
Fridel Selitsky
Hi, Jean, thanks for the support.
