The procedure for constructing a circle by three points in 3D
The procedure for constructing a circle by three points in 3D - Сообщения
#1 Опубликовано: 31.12.2016 04:11:54
Fridel Selitsky
Fridel Selitsky
Idea of ​​the algorithm taken from the publication of Alexey Ivanov
http://www.mapleprimes.com/posts/207697-Circle-In-3d-
The calculation algorithm
1. The three points are vertices of the triangle. Write three linear equations:
two equations of planes passing through the midpoints of the two sides of the triangle
perpendicular to these sides: f1 = 0, f3 = 0
and the equation of the plane which contains the triangle: f2 = 0.
2. Solve the system of equations and find the center of a circle with coordinates Cen xCen, ... zCen.
3. Find the circle radius R of the equation of a sphere with radius R and center at Cen
4. Construct a circle as the line of intersection of the sphere with the plane of the triangle (Draghilev method)
Okruzhnost'3.sm (55,35 КиБ) скачан 1207 раз(а).
Davide Carpi 02.01.2017 12:40:00, Oscar Campo 25.11.2017 00:44:00
#2 Опубликовано: 24.01.2017 13:22:48
Fridel Selitsky
Fridel Selitsky
Modified the program
OkruzhnostMod.pdf (243,54 КиБ) скачан 811 раз(а).
OkruzhnostMod.sm (67,93 КиБ) скачан 1157 раз(а).
Davide Carpi 25.01.2017 06:32:00, Oscar Campo 25.11.2017 00:44:00, Arie 24.01.2017 19:58:00
#3 Опубликовано: 24.11.2017 06:43:33
Fridel Selitsky
Fridel Selitsky
Changes:
1. Circle is constructed by matrix transformation, and not Draghilev Method
2. The normal to the surface passing through the given points is shown.
OkruzhnostMod3.sm (54,16 КиБ) скачан 1147 раз(а).
Davide Carpi 24.11.2017 14:53:00, Oscar Campo 25.11.2017 00:44:00, frapuano 24.11.2017 08:35:00
#4 Опубликовано: 25.11.2017 10:33:16
Thanks Ber7, saved.
#5 Опубликовано: 25.11.2017 12:21:20
Fridel Selitsky
Fridel Selitsky
Hi, Jean, thanks for the support.
