Beta: SMath Studio 0.99.7219 (07 October 2019)
Beta: SMath Studio 0.99.7219 (07 October 2019) - Messages
#1 Posted: 10/7/2019 12:06:36 PM
1,443 likes in 2,935 posts.
SMath Studio
Changes introduced in current build 0.99.7219
Improvements
  • Arial made a default font for Text Region.
Corrections
  • Changing font Familty and font size for several selected Regions fixed;
  • Fixed exception happens on some environments when rendering font names in font selector;
  • Fixed issue related to empty Descriptions on file open;
  • Select All supported inside embedded Regions now.
Miscellaneous
  • Worksheet files layout updtaed to be supported by earlier SMath Studio versions;
  • The following functions allows to calculate 0^0 now: sum(4), product(4), eval(1);
  • Situations with unwanted change of font options fixed.
Download
SMathStudioDesktop.0_99_7219.Mono.tar.gz (1.4 MiB) downloaded 2401 time(s).
SMathStudioDesktop.0_99_7219.Setup.msi (2.27 MiB) downloaded 6201 time(s).
8 users liked this post
Radovan Omorjan 10/7/2019 12:13:00 PM, NDTM Amarasekera 10/7/2019 12:27:00 PM, sergio 10/7/2019 12:46:00 PM, frapuano 10/7/2019 2:52:00 PM, dio pants 10/7/2019 3:34:00 PM, Ryan Freund 10/7/2019 5:20:00 PM, Вячеслав Мезенцев 10/7/2019 5:48:00 PM, Arie 10/8/2019 1:12:00 PM
#2 Posted: 10/7/2019 6:05:48 PM
Ryan Freund
Ryan Freund
20 likes in 339 posts.
This is great, thank you.
A few comments:
It would be nice to set the default text. If I change it, it will not remain as the default.
The default font size now changes correctly, however it remains shown as 10 (graphically) in the ribbon.
When using the "show description" feature. The text returns down a line when using " or ' characters.
Edit:
I don't think the font style of "descriptions" can be changed.
#3 Posted: 10/20/2019 1:57:56 PM
598 likes in 1,380 posts.
I use monospace characters in my documents; so I stick with courier new, fixedsys, typewriter fonts. New created description texts in 7219 always have Arial font and it can't be changed. I need to copy and modify a variable from earlier versions which has precreated description text.
And font can be changed to anything with a text editor like notepad.
#4 Posted: 10/22/2019 5:03:52 PM
Jacques CHEN
Jacques CHEN
0 likes in 11 posts.
I think solve function cant solve with unit,who can help me?
Test about solve.sm (5.89 KiB) downloaded 1572 time(s).
#5 Posted: 10/22/2019 6:15:16 PM
manolo
manolo
8 likes in 9 posts.
Try this:
#6 Posted: 10/22/2019 6:19:06 PM
Why not work maths as they exist from the cave man, i.e: unitless ?
#7 Posted: 10/23/2019 6:07:38 AM
127 likes in 342 posts.
You can also use FindRoot from the NonLinearSolvers plugin, well documented, for details, in Martin Kraska guide
#8 Posted: 10/23/2019 1:07:58 PM
#9 Posted: 10/23/2019 4:22:24 PM
This is the version with the Maxima plugin:
solveunits.sm (7.86 KiB) downloaded 1563 time(s).
sergio 10/24/2019 4:23:00 AM
#10 Posted: 10/23/2019 4:35:41 PM
Jacques CHEN
Jacques CHEN
Try this:
in this way, I need install maple?
#11 Posted: 10/23/2019 4:37:04 PM
Jacques CHEN
Jacques CHEN
I am try to solve EQ with unit. Thank you too!
#12 Posted: 10/23/2019 4:39:40 PM
Jacques CHEN
Jacques CHEN
Thank you! this way is very good. But I find another problem.
Test about solve.sm (6.49 KiB) downloaded 1604 time(s).
#13 Posted: 10/23/2019 5:10:47 PM
FindRoot performs implicit assignment to x.
Therefore, you have to Clear(x) before you can solve for x again. Just as demonstrated in the Maxima example above. There, the solution is assigned explicitly using Assign() from the Maxima-Plugin
See Interactive Handbook> Function Index> Assign or Solve
#14 Posted: 10/23/2019 6:05:54 PM
Jacques CHEN
Jacques CHEN
thank you sir. I solve my problem!
#15 Posted: 10/24/2019 8:52:58 AM
I solved my problem !
Read carefully the attached.
Solve Given_Find [System Demo epsilon].sm (25.89 KiB) downloaded 1384 time(s).
#16 Posted: 10/24/2019 11:09:03 AM
Read even more carefully the attached.
All in all: Smath solvers has solved all Mathcad 11 great projects.
The bugger in Smath FindRoot is 'ε'
i.e: needed or detrimental [detrimental in attached Butler].
To make it clear, Mathcad Given Find is Mathsoft proprietary.
It has no competition in difficult applications.
Some projects toke weeks, from brain storm collaboration.
Cheers ... Enjoy Butler.
Solve Given_Find [CO2_6179].sm (34.34 KiB) downloaded 1436 time(s).
#17 Posted: 10/24/2019 12:48:45 PM
Hello Jean,
It seems something is wrong here. Results seems to be doubtful and I think epsilon is missing as a third argument in FindRoot()
If I add it
Playing with the fourth argument will give
Moreover, roots() will fail
#18 Posted: 10/24/2019 5:54:18 PM
Hello Jean,
Quite right Radovan, many things don't cut the mustard !
1. "roots" fails in your version, but superb in my native SS 6179.
2. "epsilon" deteriorates the solver in this FindRoot application.
3. The system reacts like proportional/commutative wrt reactants.
What matters is the balance [Alkalinity] 0.0000012
sounds pretty good to me ? Should revisit the paper problem,
Reference: Butler, Carbon Dioxide Equilibria, Prob. 2-11, pg 41
#19 Posted: 10/25/2019 9:58:44 AM
I could not retrieve the very original.
Here is something.
https://www.isws.illinois.edu/pubdoc/CR/ISWSCR-171.pdf
