faculty operator crashes smath
faculty operator crashes smath - Messages
#1 Posted: 8/24/2013 6:25:32 AM
see image. You can choose [Continue] from the error dialog and then have to remove (blindly) the region where you typed the offending contents. Version 0.96.4909, Win7
#2 Posted: 8/25/2013 11:01:53 PM
rmix22
rmix22
3 likes in 15 posts.
I am using the same SMath version but Win XP SP3 and cannot duplicate the crash you describe. If I follow your steps a get (a+b)!= and depending upon if a and b would have been assigned values either an error a sof "a" being unknown or the correct numeric result.
Martin Kraska 8/26/2013 1:24:00 AM
#3 Posted: 8/26/2013 1:22:41 AM
Thanks, You are right, there is a bug in the bug report. Must be a*b instead of a+b.
after a*b typing space extends the underline cursor to the expression a*b. When you then type !, the underline shrinks to b! and typing = causes the crash.
#4 Posted: 8/26/2013 4:59:17 AM
this is confirmed
best regards,
Davide
#5 Posted: 8/26/2013 5:02:31 AM
rmix22
rmix22
Yes, I can confirm that bug now.
#6 Posted: 3/23/2014 7:05:47 AM
Bug seems to be fixed, cannot reproduce it any more in 0.97.5189.
