faculty operator crashes smath
faculty operator crashes smath - Сообщения
#1 Опубликовано: 24.08.2013 06:25:32
see image. You can choose [Continue] from the error dialog and then have to remove (blindly) the region where you typed the offending contents. Version 0.96.4909, Win7
#2 Опубликовано: 25.08.2013 23:01:53
rmix22
rmix22
3 сообщений из 15 понравились пользователям.
I am using the same SMath version but Win XP SP3 and cannot duplicate the crash you describe. If I follow your steps a get (a+b)!= and depending upon if a and b would have been assigned values either an error a sof "a" being unknown or the correct numeric result.
Martin Kraska 26.08.2013 01:24:00
#3 Опубликовано: 26.08.2013 01:22:41
Thanks, You are right, there is a bug in the bug report. Must be a*b instead of a+b.
after a*b typing space extends the underline cursor to the expression a*b. When you then type !, the underline shrinks to b! and typing = causes the crash.
#4 Опубликовано: 26.08.2013 04:59:17
this is confirmed
best regards,
Davide
#5 Опубликовано: 26.08.2013 05:02:31
rmix22
rmix22
Yes, I can confirm that bug now.
#6 Опубликовано: 23.03.2014 07:05:47
Bug seems to be fixed, cannot reproduce it any more in 0.97.5189.
