1 Pages (7 items)
Adding Margins to worksheets - Adding margins - Messages
#1 Posted: 1/14/2021 6:12:22 AM
Is there a way of adding Margins to a Worksheet ?
I'd like to put a vertical line down the RH side of the page approx 25mm from the edge
Thanks
Thanks
Peter J Francis
Twitter: @PeterJFrancis
Thermal Engineer , Maker , Pilot
#2 Posted: 1/14/2021 6:44:05 AM
For margins: Menu -> File -> Page Setup
For the vertical line: Menu -> Insert -> background -> background image and insert a background file prepared with your favorite decorations
#3 Posted: 1/14/2021 7:19:44 AM
Thanks you , I didn't realise that was possible !
All the best
Peter
All the best
Peter
Peter J Francis
#4 Posted: 1/14/2021 2:25:00 PM
WroteI'd like to put a vertical line down the RH side of the page approx 25mm from the edge
You can have more than just a line.
If you have the message "can't find file ... just ignore.
This is because Smath stores the two regions internally
and can't retrieve because incomplete [no argument] regions.
Page13 Margin.sm (3.3 KiB) downloaded 826 time(s).
#6 Posted: 1/15/2021 6:52:34 AM
Thanks for the reply Jean,
your suggestion re 'adjustable length/width' looks exactly what I want but
I'm not familiar with image regions so I don't really understand how to impliment it
Do you have an example I could look at ?
Thanks
Thanks
Peter J Francis
#7 Posted: 1/15/2021 10:28:30 AM
... like this Peter, now slide wherever in the work sheet.
Template Margin Line RGBYCM.sm (34.78 KiB) downloaded 739 time(s).
1 Pages (7 items)
