Adding Margins to worksheets
Adding Margins to worksheets - Adding margins - Сообщения
#1 Опубликовано: 14.01.2021 06:12:22
Peter J Francis
Peter J Francis
Is there a way of adding Margins to a Worksheet ?
I'd like to put a vertical line down the RH side of the page approx 25mm from the edge
Thanks
Peter J Francis Twitter: @PeterJFrancis Thermal Engineer , Maker , Pilot
#2 Опубликовано: 14.01.2021 06:44:05
For margins: Menu -> File -> Page Setup
For the vertical line: Menu -> Insert -> background -> background image and insert a background file prepared with your favorite decorations
Peter J Francis 14.01.2021 07:18:00, Andrey Ivashov 14.01.2021 07:26:00
#3 Опубликовано: 14.01.2021 07:19:44
Peter J Francis
Peter J Francis
Thanks you , I didn't realise that was possible !
All the best
Peter
#4 Опубликовано: 14.01.2021 14:25:00
You can have more than just a line.
If you have the message "can't find file ... just ignore.
This is because Smath stores the two regions internally
and can't retrieve because incomplete [no argument] regions.
Page13 Margin.sm (3,3 КиБ) скачан 1323 раз(а).
#5 Опубликовано: 14.01.2021 17:23:48
... or like this: adjustable length/width in RGBYMC.
Peter J Francis 15.01.2021 06:53:00
#6 Опубликовано: 15.01.2021 06:52:34
Peter J Francis
Peter J Francis
Thanks for the reply Jean,
your suggestion re 'adjustable length/width' looks exactly what I want but
I'm not familiar with image regions so I don't really understand how to impliment it
Do you have an example I could look at ?
Thanks
#7 Опубликовано: 15.01.2021 10:28:30
... like this Peter, now slide wherever in the work sheet.
Template Margin Line RGBYCM.sm (34,78 КиБ) скачан 1150 раз(а).
