Graph animation
Graph animation - Messages
#21 Posted: 12/30/2012 10:06:59 AM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Happy.sm (7.95 KiB) downloaded 1327 time(s).
Andrey Ivashov 1/3/2013 10:00:00 AM, Davide Carpi 12/30/2012 10:12:00 AM
#22 Posted: 2/16/2013 4:24:34 AM
Fridel Selitsky
Fridel Selitsky
optical illusion
The idea is taken from the site
http://www.mapleprimes.com/maplesoftblog/35171-Its-Better-With-Maple
Although the vertical distance between the curves is constant,
it seems that with increasing distance from the axis of Y, they are getting closer.
Animation helps to overcome this optical illusion
Illusion.sm (5.04 KiB) downloaded 1346 time(s).
Davide Carpi 2/16/2013 7:42:00 AM
#23 Posted: 2/24/2013 12:04:26 PM
Fridel Selitsky
Fridel Selitsky
Rolling disk on a parabola
ParCyc.smz (4.79 KiB) downloaded 1391 time(s).
Davide Carpi 2/24/2013 2:36:00 PM
#24 Posted: 3/2/2013 1:16:50 AM
Fridel Selitsky
Fridel Selitsky
Bullseye Illusion
The idea is taken from the site:
[url]: http://demonstrations.wolfram.com/BullseyeIllusion/[/url]
Although the white region has the same area as the blue ring, it appears to be larger
Bullseye.smz (2.92 KiB) downloaded 1383 time(s).
ioan92 7/28/2013 4:27:00 PM, Davide Carpi 3/2/2013 2:23:00 PM
#25 Posted: 7/28/2013 2:41:20 PM
Fridel Selitsky
Fridel Selitsky
Animation examples from the book “Introduction to Statics and Dynamics
by Rudra Pratap, Andy Ruina.Publisher: Cornell University 2009”
http://archive.org/download/ost-engineering-ruinapratap8-21-10/RuinaPratap8-21-10.pdf
Planar motion1.smz (74.44 KiB) downloaded 1415 time(s).
Davide Carpi 7/28/2013 3:51:00 PM, ioan92 7/28/2013 4:27:00 PM
#26 Posted: 9/12/2013 2:13:27 PM
Fridel Selitsky
Fridel Selitsky
Three Dissections by Leonardo da Vinci
http://demonstrations.wolfram.com/ThreeDissectionsByLeonardoDaVinci/
Leo2.smz (5.61 KiB) downloaded 1307 time(s).
Martin Kraska 9/12/2013 3:58:00 PM, Davide Carpi 9/16/2013 8:48:00 AM
#27 Posted: 9/16/2013 8:46:53 AM
kilele
kilele
134 likes in 397 posts.
Challenge for Ber7 :d
This would be a great SMath animation : Heatherwick's Rolling Bridge
See it in action on this video at 1 minute and 25 seconds :
?t=1m25s
Fridel Selitsky 9/16/2013 1:22:00 PM, Davide Carpi 9/16/2013 1:37:00 PM
#28 Posted: 9/16/2013 1:22:27 PM
Fridel Selitsky
Fridel Selitsky
Thank you for the wonderful example .
I'll try to implement it.
#29 Posted: 9/19/2013 12:54:23 AM
Fridel Selitsky
Fridel Selitsky
The Rolling Bridge
Bridge.smz (636.87 KiB) downloaded 1483 time(s).
3 users liked this post
Davide Carpi 9/19/2013 12:56:00 AM, Вячеслав Мезенцев 9/19/2013 11:22:00 AM, ioan92 9/25/2013 5:13:00 PM
#30 Posted: 9/25/2013 4:42:16 PM
lrcvs
lrcvs
3 likes in 2 posts.
Nice, Rolling Bridge!
See you this:
The author
Davide Carpi 9/25/2013 5:52:00 PM, Fridel Selitsky 9/25/2013 6:35:00 PM
#31 Posted: 10/3/2013 3:55:36 AM
Fridel Selitsky
Fridel Selitsky
http://ruina.tam.cornell...k/RuinaPratap8-21-10.pdf
A spring-mass system in space
A spring-mass system consists of two masses, m1 = 10 kg and m2 = 1 kg,
and a weak spring with stiffness k = 1N/m. The spring has zero relaxed
length.The system is in 3-D space where there is no gravity. Track the
motion of the system for the next 20 seconds. Plot the trajectory of
the two masses in space. The 3-D animation showing the trajectory of the
two masses obtained from the numerical solution . From the plot, it seems
like the smaller mass goes around the bigger mass as the bigger mass moves on its trajectory.
springMass4smz.smz (5.49 KiB) downloaded 1368 time(s).
Davide Carpi 10/3/2013 5:39:00 AM
#32 Posted: 10/3/2013 5:32:30 AM
Brian Runagle
Brian Runagle
13 likes in 27 posts.
Nice one Ber7!
archive.org had a problem with the link. The book can be found here:
http://ruina.tam.cornell.edu/Book/RuinaPratap8-21-10.pdf
Brian
#33 Posted: 10/3/2013 6:37:02 AM
Fridel Selitsky
Fridel Selitsky
Thank you very much, corrected.
Davide Carpi 10/3/2013 8:13:00 AM
#34 Posted: 4/21/2018 2:34:39 PM
Fridel Selitsky
Fridel Selitsky
Animation of NPlot and 3d Plot graphs
The program is designed for graphs that do not have a built-in
animation capabilities
3dplot mk.sm (8.5 KiB) downloaded 1208 time(s).
NplotAnimation.sm (14.61 KiB) downloaded 1246 time(s).
frapuano 4/23/2018 3:02:00 AM
