1 Pages (20 items)
Beam calculation - Ber7 - Messages
#1 Posted: 11/19/2011 4:24:17 PM
https://smath.com/wiki/GetFile.aspx?File=Beam.rar
Oscar Campo 11/19/2011 11:33:00 PM
#2 Posted: 11/20/2011 10:51:08 AM
https://smath.com/wiki/GetFile.aspx?File=Cantilever.rar
#3 Posted: 11/20/2011 10:51:45 AM
Ber7,
You amaze me with your use of graphics in SMath. I'm a civil engineer and use SMath for calculations just like this but without the pictures.
Could you post your SMath sheet in a zip file so I can see how you do it? I don't use RAR. Thanks.
Ed
#4 Posted: 11/20/2011 3:42:36 PM
Ed
https://smath.com/wiki/GetFile.aspx?File=Cantileverzip.zip
https://smath.com/wiki/GetFile.aspx?File=Beamzip.zip
Ed
#5 Posted: 11/20/2011 4:41:50 PM
Ber7,
Your animations and drawings always amaze me. Thanks.
Ed
#6 Posted: 11/21/2011 5:38:01 AM
https://smath.com/wiki/GetFile.aspx?File=Contin%5d.zip
#7 Posted: 11/24/2011 5:06:47 AM
https://smath.com/wiki/GetFile.aspx?File=ElastFound.zip
#8 Posted: 4/3/2012 7:14:42 PM
Hello.
This is very nice. I am civil ingenieer & I will use it. Thanks.
However it is dangerous to use the function x>Lf.
I found it out in my own beam programming.
When changing direction of concetrated forces, the graph of shearing force has to jump once up & once down.
And for the following input it does not!
It seems to me, the function x>Lf does not work correctly each time.
Regards Olik
SMath files: beam 3 & 4.zip
Regards Olik
#10 Posted: 4/3/2012 10:52:33 PM
Thank you, kmihaylovich, the file is corrected.
Regards,Ber7
Regards,Ber7
#11 Posted: 4/4/2012 2:04:53 AM
Thank you! This is already fixed and will work correctly even without eval function into the next SMath Studio release.
#12 Posted: 4/4/2012 1:58:31 PM
Thanks to all. The eval function seems to be a good way.
And if You fix this little bug, it will be the best.
Regards, Olik
Regards, Olik
#16 Posted: 6/11/2013 5:10:10 AM
Graphics with shading
(http://en.smath.info/forum/resource.ashx?a=1691)
AnimBeam2.sm (38.63 KiB) downloaded 1572 time(s).
4 users liked this post
Вячеслав Мезенцев 6/11/2013 12:00:00 PM, ioan92 6/11/2013 5:58:00 AM, IVR 6/11/2013 12:39:00 PM, Davide Carpi 6/12/2013 7:18:00 PM
#17 Posted: 6/12/2013 11:05:41 AM
Cantilever-new edition
https://smath.com/wiki/GetFile.aspx?File=CantileverENExe.rar
CantileverEN.smz (18.82 KiB) downloaded 1692 time(s).
#19 Posted: 7/6/2013 2:29:47 PM
Analysis of statically indeterminate beam. Supported cantilever.
Beam fixed at the one end supported an the other
https://smath.com/wiki/GetFile.aspx?File=Konsol%2bopora.rar
Konsol+opora.smz (134.15 KiB) downloaded 1688 time(s).
1 Pages (20 items)
