How to solve Berlin Airlift Linear Optimization Problem
How to solve Berlin Airlift Linear Optimization Problem - Simplex LP - Сообщения
#1 Опубликовано: 19.12.2017 10:01:12
usamakhan
usamakhan
4 сообщений из 84 понравились пользователям.
How will you go about solving following problem in Smath
Problem statement is as follows:
Цитата
On June 24, 1948, the former Soviet Union blocked all land and water routes through East Germany to Berlin. A gigantic airlift was organized using American and British planes to supply food, clothing and other supplies to more than 2 million people in West Berlin. The cargo capacity was 30,000 cubic feet for an American plane and 20,000 cubic feet for a British plane. To break the Soviet blockade, the Western Allies had to maximize cargo capacity, but were subject to the following restrictions: No more than 44 planes could be used. The larger American planes required 16 personnel per flight; double that of the requirement for the British planes. The total number of personnel available could not exceed 512. The cost of an American flight was $9000 and the cost of a British flight was $5000. The total weekly costs could note exceed $300,000. Find the number of American and British planes that were used to maximize cargo capacity.
Based on this the author & using an online LP solver I have:
http://prntscr.com/hpk4j5
#2 Опубликовано: 19.12.2017 13:45:04
You can use the "simplex" package in Maxima (linear optimization)
See page Examples> Maxima usage> Linear optimization in the interactive handbook.
Example maxima linear optimization.sm (41,89 КиБ) скачан 1128 раз(а).
#3 Опубликовано: 19.12.2017 21:12:22
Maybe plot the problem 1rst ?
Next solve solely with Smath, whereas Maxima is not component of stable 6179.
#4 Опубликовано: 20.12.2017 10:22:16
usamakhan
usamakhan
Thanks for the answers Jean would you be kind enough to attach the .sm file too. For field engineers like us your math skills seems rather cryptic & is digested properly after 2/3 days of experimenting
#5 Опубликовано: 20.12.2017 11:59:15
Here is + some extra stuff. Maybe there is way to draw an inscribed 3D ?
Solve GivenFind Critical Region Copy.sm (39,35 КиБ) скачан 1169 раз(а).
#6 Опубликовано: 20.12.2017 19:59:09
CBG
CBG
Using Smath Studio with Maxima and the example of Martin Kraska.
Metodo_Simplex.sm (52,26 КиБ) скачан 1164 раз(а).
Carlos
#7 Опубликовано: 21.12.2017 15:27:26
CBG
CBG
Here is a small and simple Simplex algorithm without the use of the Maxima function.
Small_Simplex_Algorithm.sm (16,35 КиБ) скачан 1190 раз(а).
Carlos
CAUTION: The algorithm is NOT TESTED, but it works well for this example.
It is necessary to refine it so that it work in all cases.
frapuano 21.12.2017 18:37:00
#8 Опубликовано: 21.12.2017 16:10:07
Thanks Carlos for the "Simplex algo"
#9 Опубликовано: 22.12.2017 01:40:32
CBG
CBG
A little Simplex algorithm improved
Small_Simplex_Algorithm_Improved.sm (88,5 КиБ) скачан 1138 раз(а).
Carlos
#10 Опубликовано: 22.12.2017 02:46:37
CBG
CBG
I'm sorry, I found a bug in the Simplex algorithm.
Now it's fixed.
Small_Simplex_Algorithm_Improved_2.sm (135,66 КиБ) скачан 1166 раз(а).
Carlos
#11 Опубликовано: 22.12.2017 10:12:27
That huge number in the program, can be replaced by ∞ [Smath machine number]
RemToDo => check vs Mathcad
First A[i ... badly indexed.
Small_Simplex_Algorithm_Improved_2.sm (140,42 КиБ) скачан 1166 раз(а).
CBG 22.12.2017 12:54:00
#12 Опубликовано: 22.12.2017 12:57:52
CBG
CBG
Thanks Jean, Now we just have to continue testing the Simplex algorithm, to identify possible faults.
regards
Carlos
#13 Опубликовано: 22.12.2017 13:38:07
I have tested only this one => 1/1 Mathcad 11
Gorgeous, hope for more good !
Undocumented Copy.sm (25,63 КиБ) скачан 1207 раз(а).
