Fast way to enter powers of 10
Fast way to enter powers of 10 - It is cumbersome to enter the powers of 10 everywhere. A shortcut would help - Сообщения
#1 Опубликовано: 14.05.2018 02:34:06
henry crun
henry crun
0 сообщений из 34 понравились пользователям.
It would really help to have a fast way of entering powers of ten.
In electronics, every number has a large exponent and entering 15 * 10 ^ 7 is harder than 15E7
(8 keystrokes vs 4)
I think that there should be an option to treat the special case of E , as the exponent operator.
* is automatically inserted when going from numbers to letters, but this is no problem.
ie new behaviour: 15E6 -> 15*10^6
old: 15E6 -> 15*E6
Problem: variable names like E or E6FilmMass, would need to have an operator explicitly used, and could not use the current automatic * operator insertion
Alternatives: use ctrl+E or alt+E as simple keystroke macro to insert: *10^
#2 Опубликовано: 14.05.2018 08:23:08
Features request ... What features request ?
#3 Опубликовано: 17.05.2018 12:42:41
Oscar Campo
Oscar Campo
(8 keystrokes vs 4)
Alternative: Define a function E()
frapuano 17.05.2018 13:27:00, tomracing 14.09.2020 09:05:00
#4 Опубликовано: 25.08.2020 07:01:07
henry crun
henry crun
not a bad idea. I could also define all the common positives eg
e3:=1000
and maybe the negatives
n3:=10^-3
it would certainly help with matrices as it is more compact too.
With the snippet manager, quite viable.
I do think it would also be good to consider (optionally) using the common exponent notation for display as it is much more compact in arrays. When an array is full of *10^3 it really blows out the size on the page.
#5 Опубликовано: 25.08.2020 07:33:04
You can write any multiplier in the unit placeholder of results.
#6 Опубликовано: 25.08.2020 08:05:22
henry crun
henry crun
True, but only in the very limited number of cases where all elements have the same exponent.
#7 Опубликовано: 25.08.2020 09:40:39
Make your own feature to suit peculiar project.
This notation is native in OriginLab.
Maths e(n).sm (14,94 КиБ) скачан 1581 раз(а).
#8 Опубликовано: 25.08.2020 18:17:13
Show the array creation c/w the blown page size.
No monkey see, no monkey do !
#9 Опубликовано: 27.08.2020 11:49:20
How about the Table region?
sci.sm (13,5 КиБ) скачан 1579 раз(а).
Alvaro 28.08.2020 05:33:00
#10 Опубликовано: 28.08.2020 02:31:05
henry crun
henry crun
That's a useful solution. I see that when scientific is selected, however, that it loses the units.
Is the table plugin part of the closed source, or an open source add on that might be fixable?
[is it: https://smath.info:8443/!/#public/view/head/plugins/TableRegion ?]
However, I would just prefer to have numeric formatting work well in the first place.
#11 Опубликовано: 28.08.2020 03:51:11
The plugin is open source, just like all third-party plugins.
#12 Опубликовано: 28.08.2020 08:18:28
Table region is part of the SS download as old as SS 6179.
Fix what to this superb delivery ?
#13 Опубликовано: 29.08.2020 10:36:56
It does not lose what's not specified.
Table Scientific.sm (20,56 КиБ) скачан 1646 раз(а).
