there is any mistake, Please solve this attached file
there is any mistake, Please solve this attached file - function or unit conversion error - Сообщения
#1 Опубликовано: 18.08.2022 03:53:39
John Bhang
John Bhang
Файл не найден.Файл не найден.Файл не найден.
I can not have a right calculation results though I tried to resolve this several times.
When I am using the matrix format, I get the wrong results.
In case that I am using the simple format x=20ft, I get the right result.
Please help me out.
#2 Опубликовано: 20.08.2022 21:45:47
Since x is a matrix and you are using it with other variables, you have to use vectorize.
You can either write it as a function or click to its button on toolbar > matrices.
#3 Опубликовано: 21.08.2022 20:34:59
You can make each demand algo style
1rst demand exemplified.
The algo style will support in-situ infinite command line.
... in-situ infinite command line wrt [u,v,x]
A damned elegant Pro. style project !
#4 Опубликовано: 22.08.2022 09:12:54
Here is your file fixed.
2 psc beam bridge(US unit)-Dead Load_fixed.sm (188,45 КиБ) скачан 1287 раз(а).
