Create a graph with x-y plot
Create a graph with x-y plot - Сообщения
#1 Опубликовано: 11.02.2023 06:35:47
Beyaz
Beyaz
0 сообщений из 19 понравились пользователям.
Hey guys,
im trying to plot my function with x-yplot (addon) but it doesnt work. I will be happy if can someone can help me.
i define two functions (with If-clauses) and now I have to put it in x-y-plot.
Thanks for helping
Pfahlsetzungslinie.sm (101,89 КиБ) скачан 1283 раз(а).
#2 Опубликовано: 11.02.2023 09:51:05
I define two functions (with If-clauses) and now I have to put it in x-y-plot.
1. Start by the first red instance ... assign the demand.
2. For the plot Units don't match
3. Check if your incomplete Bolean is OK ... here shown complete.
4. What is mPa
#3 Опубликовано: 11.02.2023 11:27:05
If you want to plot, you have to eliminate units.
Either by writing a unitless function, or using units while plotting.
I would rather second one.
Pfahlsetzungslinie.sm (112,67 КиБ) скачан 1325 раз(а).
Click to enlarge
#4 Опубликовано: 11.02.2023 14:22:20
Beyaz
Beyaz
hey guys thanks. (i tryed to give you a thanks but i always get an error)
it works now. Ive realized my mistakes.
i have 2 more question.
1. is it possible to rotate the graph or function? I wanna switch x and y axis
2. i wanna make the visible spectrum of x and y axis depent on a variable. like X-Axis Max=s1 and Min=s2
//sorry for my bad english
#5 Опубликовано: 11.02.2023 16:44:13
2. I wanna make the visible spectrum of x and y axis depend on a variable. like X-Axis Max=s1 and Min=s2
I understand 1 ... 2 Not clear.
Cheers ... Jean.
#6 Опубликовано: 11.02.2023 16:46:06
... once the discrete data set in hand,
you can rotate by any angle as desired.
#7 Опубликовано: 11.02.2023 17:58:06
If I understand: once the discrete data set in hand,
very easy to range between Mi/Max.
Produce the discrete data set, I will terminate.
Cheers ... Jean.
#8 Опубликовано: 12.02.2023 01:43:27
... i have 2 more question.
Hi Beyaz.
1. Yes. For example you can use this technique over your functions
xy-yx-plot.sm (7,16 КиБ) скачан 1259 раз(а).
2. Yes. For example you can try to learn about how to use setprop in an XY plot region.
#9 Опубликовано: 12.02.2023 07:09:44
Beyaz
Beyaz
question 2: solved after find this
https://en.smath.com/forum/yaf_postsm57205_X-Y-Plot-Region.aspx
but to rotate the graph like this it didnt work. i tried your suggestions. Pfahlsetzungslinie1.sm (80,01 КиБ) скачан 1280 раз(а).
#10 Опубликовано: 12.02.2023 08:47:18
Hi. You need to specify the XYPlot index. This is how to swap axis coordinates, and reverse the y-axis. I reduce the number of points in the XYPlot to 50.
Pfahlsetzungslinie1.sm (87,42 КиБ) скачан 1300 раз(а).
#11 Опубликовано: 12.02.2023 09:12:08
But to rotate the graph like this it didn't work.
I tried your suggestions.
You haven't produced the discrete data set.
Cheers ... Jean.
Wanna Rotate.sm (14,34 КиБ) скачан 1246 раз(а).
#12 Опубликовано: 12.02.2023 14:23:09
#13 Опубликовано: 13.02.2023 07:13:49
You can also use a rotation matrix.
It works on both 2DPlot an XYplot.
churichuro 13.02.2023 16:11:00
#14 Опубликовано: 13.02.2023 10:41:33
Rotate XY.sm (486,01 КиБ) скачан 1289 раз(а).
#15 Опубликовано: 13.02.2023 15:07:49
Beyaz
Beyaz
thanks all of you guys.
now my smath tool is perfect. thanks for helping.
