Imaginary unit i<-->j
Imaginary unit i<-->j - Сообщения
#1 Опубликовано: 24.04.2016 00:21:54
Basile
Basile
I try to solve some problems in AC electric circuits.
Can I change the imaginary unit from i to j such that:
I enter data using j, and
output (from SMath) data using j?
Thanks,
Basile
#2 Опубликовано: 24.04.2016 00:28:27
Mike Kaganski
Mike Kaganski
Simple answer: no.
You may define a variable (j) or a unit ('j) equal to i, then you can use it to enter data.
But you cannot get results using it (putting it to units placeholder won't give you much).
Also you cannot use i as ordinary variable to hold arbitrary value afterwards, as this will ruin your j, too.
С уважением, Михаил Каганский
#3 Опубликовано: 24.04.2016 20:40:06
Thanks,
Basile
This the 'PJ" version [PJ = Pyjama]
1. Define imaginary user style 'j'
2. Don't re-use 'j' as index.
3. No need to spool to file, but X_Y plot
does not take unit ° in "Angle" [Not defined].
I have removed previous posting and work sheets.
Cheers, Jean
Angle Data 'j'.sm (9,59 КиБ) скачан 1224 раз(а).
Basile 24.04.2016 21:53:00
#4 Опубликовано: 24.04.2016 21:54:29
Basile
Basile
Thank you, both.
Basile
#5 Опубликовано: 25.04.2016 00:31:18
... just watch the unit system in your Engineering projects.
Angle Data 'j'.sm (16,53 КиБ) скачан 1193 раз(а).
