matrix (table)
matrix (table) - How to add matrix element - Сообщения
#1 Опубликовано: 28.09.2021 07:57:09
Adam Puczyński
Adam Puczyński
I'm newbee, sorry. I have problem. Help me?
How to add specific element of matrix or table to calculations?
#2 Опубликовано: 28.09.2021 08:14:15
If you have your matrix from calculation,
simply address the element(s) with new value.
#3 Опубликовано: 28.09.2021 08:37:33
#4 Опубликовано: 28.09.2021 09:17:41
... observe the empty place holder is a / operator.
#5 Опубликовано: 28.09.2021 10:00:40
Adam Puczyński
Adam Puczyński
Thank You Jean, but rather, I meant to extract a specific element from the matrix. Sorry but my English is very poor.
Adam
#6 Опубликовано: 28.09.2021 11:15:31
There are many more ways ... like skinning a cat.
Cheers ... Jean.
#7 Опубликовано: 28.09.2021 13:28:22
Adam
You can press [ when a variable is selected to write in the worksheet a "vector element" placeholder to access an element of a vector/matrix.
Indices are "base 1", therefore any value from 1 to the number of elements is accepted.
A single placeholder in matrices reads the values by linear indexing that is reading each element of a row before going to the next one).
You can add a second placeholder for accessing rows and columns coordinates by typing an argument separator (usually a comma or a semicolon) when the first placeholder is selected.
[ is a shortcut for the function el(1), so it is possible to create the same thing with the following sequence
write el
press TAB KEY
write matrix name
press RIGHT ARROW KEY
write 1st index number or name
[optional]
press ARGUMENT SEPARATOR KEY
write 2nd index number or name
#8 Опубликовано: 28.09.2021 16:21:01
Hi. There are many different ways to access the elements of an array. This list is not exhaustive, and does not include the submatrix function.
M.sm (10,01 КиБ) скачан 1151 раз(а).
sergio 28.09.2021 17:24:00, fedeghi 29.09.2021 03:24:00
#9 Опубликовано: 30.09.2021 06:22:06
Adam Puczyński
Adam Puczyński
Hay everybody.
Thank you so much, especially for the examples (Jean, Davide, Razonar). It brightened up a lot of problems for me regarding matrices. Once again, thank you very much. One more thing, how do you write the range of elements in an array? Regards Adam
#10 Опубликовано: 30.09.2021 07:53:25
Your question is not clear w/o an example.
If not confidential, please attach the document.
Attached, a typical example @ the red arrow.
Cheers ... Jean.
2D Plot Multitrace [Gaussian] QUICK.sm (26,2 КиБ) скачан 1004 раз(а).
#11 Опубликовано: 30.09.2021 13:37:31
... One more thing, how do you write the range of elements in an array? Regards Adam
Use vector element
or matrix element
and then put a range (with 2 or 3 arguments) in the index placeholder
