RC2: 0.99.6654 (22 March 2018)
RC2: 0.99.6654 (22 March 2018) - Сообщения
#1 Опубликовано: 21.03.2018 18:47:14
SMath Studio
Скачать
SMathStudioDesktop.0_99_6654.Mono.tar.gz (1,28 МиБ) скачан 1974 раз(а).
SMathStudioDesktop.0_99_6654.Setup.msi (2,15 МиБ) скачан 4153 раз(а).
6 пользователям понравился этот пост
sergio 22.03.2018 06:29:00, Вячеслав Мезенцев 21.03.2018 23:24:00, NDTM Amarasekera 22.03.2018 00:10:00, frapuano 21.03.2018 18:56:00, IVR 22.03.2018 15:35:00, Василий Николаевич Храмушин 23.03.2018 12:34:00
#2 Опубликовано: 26.03.2018 17:41:04
The behaviour of loops with second value seems to have improved. Is this generally fixed or just by chance?
Andrey Ivashov 28.03.2018 12:43:00
#3 Опубликовано: 27.03.2018 03:16:09
Martin_B
Martin_B
22 сообщений из 84 понравились пользователям.
Discovered following behaviour concerning pagebrakes with very long blocks:
(scroll to right if necessary)
The red marked block is so long, that it reaches the top of following page.
As you can see in the preview window, the sheet content is not printed.
Page 2 starts after the page brake with "Biegedrillknicken" when "Printing Bounds" is used.
While using "Pages view", the first printed page looks the same (mostly white) but the second page starts with the skipped content "System l=5,00m..."
Setting the font size only of the large block to something smaller so the bottom of it doesn't reach the page brake solves this issue.
#4 Опубликовано: 27.03.2018 06:52:36
Martin_B
Martin_B
Found another issue, while editing the description of a 2D plot:
When you put the cursor in the description and edit the text, a matching variable in the input data is edited simultaneously.
Screenshot: description is edited -> a second cursor appears in input data
#5 Опубликовано: 27.03.2018 09:29:54
Not clear w/o the document.
#6 Опубликовано: 27.03.2018 09:36:59
Discovered following behaviour concerning page brakes with very long blocks:
Maybe the problem is the construction ?
Document would surely help volunteers.
#7 Опубликовано: 27.03.2018 09:59:31
Martin_B
Martin_B
Here you are:
Pagebrake.sm (70,7 КиБ) скачан 1728 раз(а).
#8 Опубликовано: 27.03.2018 10:39:37
Here you are:
The long page brakes are not in the attachment !
sin(x0 something => no problem Smath 6179
#9 Опубликовано: 27.03.2018 11:16:10
Martin_B
Martin_B
Here you are:
We are here in the "RC2: 0.99.6654"-thread.
So I thought it would be clearly that I refer to 0.99.6654.
Take a look at the video (screen capture) if you don't believe what I am writing.
SMath Studio - [Pagebrake.sm] 27.03.2018 15_58_31.mp4 (2,84 МиБ) скачан 571 раз(а).
Here you are:
Sure they are (I uploaded a simplified example):
frapuano 27.03.2018 11:29:00
#10 Опубликовано: 27.03.2018 14:32:10
Your screen shot is explicit enough, but the document would help
more collab to check that particular issue or similar problem.
Nobody reported this bug, if it is an Smath bug.
#11 Опубликовано: 27.03.2018 15:00:06
Martin_B
Martin_B
Found another issue, while editing the description of a 2D plot: ...
The document is linked in post #7. And the screen capture in post #9.
#12 Опубликовано: 27.03.2018 15:22:30
Arie
Arie
Here you are:
Can repeat both bugs with the provided file on 6654. Oddly enough I was able to enter a description sometimes without effecting the data field if I first clicked within the data field, then immediately clicked the description field. This only worked occasionally and seemed dependent on where I clicked within the data field.
frapuano 27.03.2018 17:47:00, Martin_B 27.03.2018 15:53:00
#13 Опубликовано: 27.03.2018 18:32:05
Bug/NObug ... pretty strange, whatever.
The document attached does not contain
the live Smath part in snippet # 3
There is one known shadow in context
You can't define a function starting with 'if'
if(a,b,x):=fnct(a,b,x) ... if NOT allowed.
Quick tip to get rid of "sometimes without effecting the data field"
1. in the description, type few letters not common to data field
2. once finished the description, zap the fake letters.
#14 Опубликовано: 28.03.2018 03:08:09
Martin_B
Martin_B
The document attached does not contain the live Smath part in snippet # 3
To avoid "shadow in the context" I uploaded a very clean sheet (#7) which shows exactly the behaviour I described.
Really don't know why I should want to define 'if' myself.
#15 Опубликовано: 28.03.2018 09:47:11
No bug from [#7], nobody else reported.
can't explain the non-explainable.
#16 Опубликовано: 28.03.2018 12:42:23
Here you are:
Thank you! Both issues are reproduced and will be fixed asap.
Martin_B 28.03.2018 13:39:00, Arie 28.03.2018 14:40:00
#17 Опубликовано: 28.03.2018 12:43:47
Was not my goal. Looks like some refactoring might helped.
#18 Опубликовано: 28.03.2018 13:27:49
It has some interest,
but needs be distinguished by some invention.
#19 Опубликовано: 28.03.2018 15:24:13
Ruben Sidranski
Ruben Sidranski
Are you doing something wrong or bug wrt your Smath version?
My sheet has the app version. I'm on 0.99.6654. Looks like that may be the problem
https://en.smath.info/forum/yaf_postsm47682_X-Y-Plot-Region.aspx#post47680
Jean confirmed similar issue with Maxima plugin too https://en.smath.info/forum/yaf_postsm47682_X-Y-Plot-Region.aspx#post47682
#20 Опубликовано: 28.03.2018 17:46:37
Ruben Sidranski
Ruben Sidranski
"0.99.6661" fixed the x-y plugin problem
