SMath Studio 0.96.4868 (30 May 2013)
SMath Studio 0.96.4868 (30 May 2013) - Сообщения
#61 Опубликовано: 10.10.2013 08:24:16
arichardd
arichardd
Thank you very much. Helped me a lot.
#62 Опубликовано: 11.10.2013 11:28:43
Ruben Sidranski
Ruben Sidranski
Any update on the official portable version? I have not seen any nightly builds or other communication. Thanks Martin for the unofficial version as a stop gap
#63 Опубликовано: 11.10.2013 13:47:22
1 436 сообщений из 2 915 понравились пользователям.
Показать спойлер
#64 Опубликовано: 11.10.2013 15:09:35
lpolkosnik
lpolkosnik
Great program using install version would prefer portable, tried downloading but not autorized error
Keep up great work
Thanks,
Leon
#65 Опубликовано: 26.11.2013 10:48:58
Luis
Luis
I have a big problem: I installed the latest version of SMath and execute him shows me an error message: "Unable to find a version of the runtime to run this application". I have installed Windows XP with framework .net v4.0. On the other hand, I installed the same version on my Notebook with windows 7 home having built framework v4.0 .net and I have not had any problems. Could anyone tell me how to fix the problem in Windows XP?
#66 Опубликовано: 26.11.2013 14:13:21
SMath needs .NET framework 2.0.
from the Microsoft site (Version Compatibility in the .NET Framework)
Цитата
Compatibility and side-by-side execution
If you cannot find a suitable workaround for your issue, remember that the .NET Framework 4.5 runs side by side with versions 1.1, 2.0, and 3.5, and is an in-place update that replaces version 4. For apps that target versions 1.1, 2.0, and 3.5, you can install the appropriate version of the .NET Framework on the target machine to run the app in its best environment. For more information about side-by-side execution, see Side-by-Side Execution in the .NET Framework.
Here there is a list of embedded frameworks in MS OS:
What version of the .NET Framework is included in what version of the OS?
As you can see from the link above, you have to install the 2.0 Framework if your system is prior to Windows Vista
Moreover seems that users with Windows 8 or later needs to install the 3.5 framework
Цитата
It also includes the .NET Framework 3.5 SP1 as an OS component that is not installed by default. The .NET Framework 3.5 SP1 can be added or removed via the Programs and Features control panel.
#67 Опубликовано: 26.01.2014 19:46:39
ramivei
ramivei
it seems that the link to the latest portable version is not workimg
#68 Опубликовано: 27.01.2014 05:03:59
1 332 сообщений из 2 241 понравились пользователям.
That is correct. You might try the inofficial portable version, see my signature.
#69 Опубликовано: 01.04.2014 07:14:45
abelle
abelle
The SMathStudioDesktop.0_96_4868.Portable.exe downoad link on this page gave server error 401 - Unauthorized: access is denied due to invalid credentials.
I think it is a dead link.
The portable versions are very nice for testing when you can't load software on the PC.
Thanks for your excellent software, which I don't use now, but can see it will be useful when I need it.
#70 Опубликовано: 01.04.2014 11:05:45
Just follow the link in my signature.
#71 Опубликовано: 27.05.2014 04:58:28
olgapet
olgapet
Get this error with the linux package:
gzip: stdin: invalid compressed data--crc error
tar: Child returned status 1
tar: Error is not recoverable: exiting now
_____________
врати, входни врати, врати
#72 Опубликовано: 31.05.2014 10:50:27
popescu
popescu
Heloo, I can not dowload last portable win version SMathStudioDesktop.0_96_4868.Portable.exe . tell me "401 - Unauthorized: Access is denied due to invalid credentials." ??
Please can you help me ?
Regards Popescu.
#73 Опубликовано: 31.05.2014 13:39:24
Janusz
Janusz
7 сообщений из 48 понравились пользователям.
Hello Popescu,
Here:
Portable version.
you be able download the last portable version.
Janusz
