Flexible Export to image formats
Flexible Export to image formats - Сообщения
#1 Опубликовано: 22.07.2012 15:59:44
Edit: Issue solved by availability of the Snapshot region.
this proposal is for those who need to integrate well defined parts of smath sheets into other documents. This need will persist as long as smath is not a full featured text system (and I am not voting in favour of such effort, as that would distract from bug fixing and math feature extension).
Currently, my personal procedure for integration of smath in Word and Powerpoint as well as Latex (LyX) is via snipping tool in Win7 and the clipboard. In LyX, when pasting images from the clipboard, you are asked to provide a filename and the image is saved to a file.
When the smath sheet is changed, than all affected images require manual update. The feature request is on automating that process. Of course, there might be various GUI concepts to support this export. What I think of is a "export region", that can be inserted via "Insert" menu or arbitrary hotkeys or right button menu in the sheet canvas. Insert point acts as upper left corner of the region, the lower right corner is placed by dragging and releasing the mouse button. A default file name and (configurable) export type is assigned. Visual feedback might be via a light grey outlined rectangle in the background, headed by the file name, extension indicating the export format. Export regions, of course, would not print.
Edit options include the change of filename and format (extension) as well as changing position of the corners by dragging with the mouse. The region should be anchored at the upper left corner. If contents below is added, then it is up to the user to enlarge the export region accordingly.
The export is executed whenever the file is saved (or upon request).
Then, in the target application, you just insert links to the exported files. LyX can be configured such that upon clicking on the imported image, smath is invoked with the corresponding sm file. That would provide a nice workflow:
  • Click one of the images in LyX
  • SMath opens with the related sm file
  • Make your changes (eg. just check if everything is still valid with the newest SMath version)
  • Save the file and close SMath
  • The images in your text are automatically updated
Could be a bit tricky to set up, as there is not a one to one relation between sm files and image files as multiple image files may result from a single sm file.
Best regards, Martin Kraska
Davide Carpi 31.07.2012 05:17:00
#2 Опубликовано: 31.07.2012 05:16:56
Hi mkraska,
I think that a good solution could be the improvement of "save as image files" with a new voice "save as multiple image files" (or a checkkbox "save each page as separate file" ), where each SMath page is saved as a single image files (f.e. a 2 pages sheet should output 2 files, filename_001.png and filename_002.png)
regards,
w3b5urf3r
#3 Опубликовано: 19.01.2013 15:47:44
Hello w3bsurf3r,
now that you are master of export and import, I would rise again the issue of automatic export regions. Initially I proposed to create a new region type ("export region" ) with properties described in the topic starter post. You proposed to save the sheet to images, perhaps splitted into page images. Image export of all regions is already possible by using html export via File> Save as.
How about just using the foldable region delimiters for export markup?
The idea is: whenever the plugin sees an area region with a file name as title (identified by supported name extensions) then it tries to export the contents of the area region to a file of that name and format. The images do not contain the region boundary and are trimmed to the size needed to show the included regions. Thus there is nothing to do in the target document except including a link to the file.
The target file is then automatically updated whenever you change the source document.
One might argue what event should trigger that search and export. Options would be:
- any re-calculation of the sheet (which might slow down the GUI). Also, there might be the danger of ruining previously exported images e.g. if some plugin is broken.
- upon save operations
- upon explicit request (via special GUI element). I would see the danger to forget this before closing the sheet after changes.
I prefer the second option (execute export whenever and only when I save the file).
Could that be done with reasonable effort? It would be a significant simplification for handbook-writing or generating images for forum posts.
Martin
Kl-TM1-12-1.sm (75,5 КиБ) скачан 1386 раз(а).
#4 Опубликовано: 20.01.2013 14:57:34
Hello w3bsurf3r,
Martin
Maybe, I have a couple of ideas...
#5 Опубликовано: 22.03.2013 12:38:38
Here there is a modified ImageFileType plugin that save the screenshot of the entire worksheet (exactly like the built-in plugin) and a chunk of the screenshot for each page (when there are many pages). Actually I'm not able to retrieve informations from the area primitives, so separators are ignored.
NOTE: BACKUP YOUR BUILT-IN ImageFileType.dll BEFORE INSTALLING THIS PLUGIN.
regards,
w3b5urf3r
ImageFileType_source.7z (1,66 КиБ) скачан 704 раз(а).
Martin Kraska 23.03.2013 13:56:00
#6 Опубликовано: 23.03.2013 13:55:42
Hi Davide,
thank you for approaching the feature requested in this topic. I just tried the plugin by extending an existing sheet by a text region on the second page, immediately after the line break preview in smath.
The The separators are ignored as mentioned in your post. However, they affect the page break preview in smath and should be removed if control over what is printed to which image is required.
In order to be used for generating handbook images, the images would need to be limited to the page content's bounding box. I admit that this could perhaps be done by some batch clipping tool independently of your. In order not to produce sheets with 80% whitespace I could use smaller paper format settings. Unfortunately the item "user defined format" does not seem to work.
Image naming from within the sheet would be fine. Would it be feasible to trigger the image split by text or math regions, perhaps with the contents image="path/name.png"?
Martin
