Dynamic systems simulation.
Dynamic systems simulation. - Pendulum exmaple - Сообщения
#1 Опубликовано: 02.02.2023 19:41:33
Oichi
Oichi
4 сообщений из 35 понравились пользователям.
I saw someone here doing simulations of pendulum and other nonlinear dynamic models, I wonder how can I do that on SMath given that solutions of the ODEs is known, thanks in advance
#2 Опубликовано: 02.02.2023 22:19:19
Number of ODE's have symbolic solution.
If your DE has either of these tree forms,
Smath will spits scalar solutions wrt parameters/IC ...
One of my old baby in Mathsoft Collaboratory.
Cheers ... Jean.
Oichi 03.02.2023 04:20:00
#3 Опубликовано: 03.02.2023 04:20:26
Oichi
Oichi
Thanks, But what I meant is how to simulate the pendulum motion itself seeing the bob and how it swings. See this link
https://en.smath.com/forum/yaf_postst973_Animation-double-pendulum-and-a-pendulum-on-a-spring.aspx
#4 Опубликовано: 03.02.2023 05:28:39
In the handbook section 8.2.6 (google for kraska smath handbuch) there is an example for such animations.
The idea is to parametrize your graphics expressions with the variable t and provide a vector of values for t via context menu of the graphic area. This only works for the built-in graphics region, not for x-y plot plugin and neither for maxima.
Oichi 03.02.2023 05:32:00
#5 Опубликовано: 03.02.2023 05:32:26
Oichi
Oichi
Do you have a version that is in English?
#6 Опубликовано: 03.02.2023 08:58:41
Arie
Arie
Google translate is your friend..
https://translate.google.com/?sl=de&tl=en&op=translate&hl=en
#7 Опубликовано: 03.02.2023 09:02:31
No, but online translators nowadays are quite powerful.
#8 Опубликовано: 03.02.2023 09:20:45
Ber7 demos are 6 years before I joined Smath Community.
In the mean time, you can solve the homogeneous pendulum.
Cheers ... Jean.
ODE Pendulum Copy.sm (63,38 КиБ) скачан 1282 раз(а).
Oichi 03.02.2023 14:09:00
#9 Опубликовано: 03.02.2023 14:12:17
Oichi
Oichi
Finally, I did some animations, But I find some problems with the exported gifs. It acts like there are some missing frames while it's totally smooth inside the sheet.
Vibrating Pendulum.sm (15,9 КиБ) скачан 1302 раз(а).
#10 Опубликовано: 03.02.2023 15:04:54
Hi. This is a workaround for that bug: https://en.smath.com/forum/yaf_postsm75052_Problem-with-animated-gif-from-plot-region.aspx#post75052
However, notice that since the values of phi are numbers and not expressions, you cannot compute the derivatives of its components the way you do in D. You can check this by substituting zero for its values, and you get the same numerical solutions.
For diff(el(φ,3),t) you can use el(φ,4), and for diff(el(φ,4),t) you should use some kind of numerical estimate.
Oichi 03.02.2023 15:43:00
#11 Опубликовано: 03.02.2023 18:13:12
Oichi
Oichi
I tried it, but still same bug exist maybe it got lowered but its still there and thanks for making me notice that mistake, does that mean we cannot solve numerically such type of DEs without assumptions?
#12 Опубликовано: 03.02.2023 18:40:30
... does that mean we cannot solve numerically such type of DEs without assumptions?
Hi Oichi. Not. Remember that given F(x,x',x'',...,t) = 0 then for using numerical DEs solvers you must to find the system D(t,x) = [x', x'', ... ] with an appropriate change of variables. Which is your original analytic expression of your differential equation to be solved? This is, the one or two equations involving both all derivatives of all "x" variables, F(x,x',x'',...,t) = 0.
#13 Опубликовано: 04.02.2023 10:45:29
This version is doctored for SS versions as low as SS 6179.
To make it compatible with ODE universal plugins.
Can you update my invented vector 'phi' in red
So that the system makes sense for all visitors.
Cheers ... Jean.
Vibrating Pendulum (1).sm (24,56 КиБ) скачан 1266 раз(а).
#14 Опубликовано: 04.02.2023 11:27:01
Oichi
Oichi
Cheers ... Jean.
This example is for a pendulum that it's upper end is attached to a spring, The displacement of this upper end is Phi(1) "u" and the angular displacement of the pendulum is Phi(2) "theta". Phi(3) "u_dot" and Phi(4) "theta_dot" are the first derivatives of the upper end vertical motion and the angular displacement of the pendulum respectively.
#15 Опубликовано: 04.02.2023 15:11:46
Oichi
Oichi
I did a trick and removed the d/dt terms.. but now I got a new problem. The Adams function telling me "Cannot calculate"
Vibrating Pendulum 2.sm (107,61 КиБ) скачан 1293 раз(а).
#16 Опубликовано: 04.02.2023 15:21:26
Thanks for explaining your advanced project.
Up until now, I can only manage the homogeneous Pendulum.
Cheers ... Jean.
Oichi 04.02.2023 15:26:00
#17 Опубликовано: 04.02.2023 17:06:12
Hi. The attached file uses the techniques shown here and here. You can also obtain the equations of motion using the lagrangian with what is shown here.
Vibrating Pendulum.sm (116,24 КиБ) скачан 1321 раз(а).
Vibrating Pendulum.pdf (183,21 КиБ) скачан 760 раз(а).
Oichi 04.02.2023 17:25:00
#18 Опубликовано: 04.02.2023 17:28:59
Oichi
Oichi
Thank you so much ^^, ODEs were already obtained using Lagrangians and Hamiltonians but I did them on a paper
