1 страниц (5 вхождений)
How to calculate the effective value of segmented voltage waveform - There is the voltage waveform but segmented, tried to calculate the effective value but failed. - Сообщения
Dear Friends,
I tried to calculate the effective value of segmented voltage waveform, but failed, could you help me to fixed it? Thank you very mucn! RMS calc.sm (10,21 КиБ) скачан 858 раз(а).
Hi. This is a way. You can see also the file RMS in this post.
Also:
RMS-example.sm (17,81 КиБ) скачан 788 раз(а).
Also:
Отредактировано 09.12.2025 18:46:12
Version without killing the units:
RMS-example.sm (8,29 КиБ) скачан 788 раз(а).
In the original version, just making the periodicity function unit-proof, is sufficient:
OH! I see! Thank you Alvaro!
Wen.
Wen.
WroteHi. This is a way. You can see also the file RMS in this post.
Also:
It helps a lot, thank you very much!
wen.
wen.
WroteVersion without killing the units:
